ChaseAlex
#1 Posted : Saturday, December 12, 2009 5:16:40 PM(UTC)
ChaseAlex
Please help with any ideas on our dryer....it doens't start when the Start button is pressed; it makes a ticking noise like something is working. If I slightly move the cycle/timer dial, the dryer will go, but only for a few seconds, then will stop. If I put pressure of the cycle/timer dial, it will stay on, but only if I hold the dial. Any thoughts on what I need to do - if it's a dial replacement, is that complicated or semi-easy?
#2 Posted : Sunday, December 13, 2009 2:19:41 AM(UTC)
Replacement parts for WHIRLPOOL LGQ8000JQ4 29"gas Dryer | AppliancePartsPros.com
Here is a wiring diagram
This is probably the timer motor and is normal.
If you mean you put pressure on the timer dial and then push the push-to-start and it keeps runnig as long as you maintain the preeessure then odds are high that the timer is toast.
Sounds like the timer is toast Item 21 in Section 1.
I would open up the console and check the connectors at the timer just to be sure that one of them is not loose.
NOTE: be sure to unplug the unit when doing this.
If all OK I would replace the timer
Is fairly easy just be sure to unplug the unit.
Also mark, make yourself a diagram or replace one wire at a time on the timer.
I think you remove one screw from the top console and it then pulls forward and flips up to get into it.
ChaseAlex
#3 Posted : Saturday, December 19, 2009 5:22:51 AM(UTC)
ChaseAlex
Thank you Denman!!:)
Originally Posted by: denman Go to Quoted Post
