Discuss
Dryer shuts off after a few minutes
 in
Dryer Repair
Dryer shuts off before cycle ends. Dryer does heat up but dial does not move either in timed or more
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer shuts off after a few minutes
  #1 (permalink)
Old 12-12-2009, 12:19 PM
Junior Member
wweb12 is on a distinguished road
Default Dryer shuts off after a few minutes
Model Number: 86982100   Brand: Kenmore   Age: More than 10 years
Dryer shuts off before cycle ends. Dryer does heat up but dial does not move either in timed or more dry/less dry areas. Do you know what element needs to be replaced. This is an older dryer without a manual.
Related Models
Magic Chef 86HA-1 SURFACE UNIT- ELE
Magic Chef 86HK-1 SURFACE UNIT- ELE
Magic Chef 86HN-1 SURFACE UNIT- ELE
Magic Chef 86HS-1 SURFACE UNIT- ELE
Magic Chef 86HY-1 SURFACE UNIT- ELE
Magic Chef 86LA-1 SURFACE UNIT- ELE
Magic Chef 86LK-1 SURFACE UNIT- ELE
Magic Chef 86LN-1 SURFACE UNIT- ELE
Magic Chef 86LS-1 SURFACE UNIT- ELE
Magic Chef 86LW-1 SURFACE UNIT- ELE
Hoover 87
Amana 8700.A MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8710PA SURFACE UNIT- ELE
Magic Chef 8710PB SURFACE UNIT- ELE
Magic Chef 8710PS SURFACE UNIT- ELE
Magic Chef 8710PW SURFACE UNIT- ELE
Magic Chef 8710VB SURFACE UNIT- ELE
Magic Chef 8710VD SURFACE UNIT- ELE
Magic Chef 8710VS SURFACE UNIT- ELE
Magic Chef 8710VV SURFACE UNIT- ELE
Magic Chef 8720PA SURFACE UNIT- ELE
Magic Chef 8720PS SURFACE UNIT- ELE
Magic Chef 8720PW SURFACE UNIT- ELE
Magic Chef 8720VB SURFACE UNIT- ELE
Magic Chef 8720VD SURFACE UNIT- ELE
Magic Chef 8720VQ SURFACE UNIT- ELE
Magic Chef 8720VS SURFACE UNIT- ELE
Magic Chef 8720VV SURFACE UNIT- ELE
Amana 874.000 RANGE- S/C S/I DDRAFT GAS
Amana 874.001 RANGE- S/C S/I DDRAFT GAS
Amana 874.301 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.302 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.304 MWAVE - FAMILY SIZE (60 HZ)
Amana 874.305 MWAVE - FAMILY SIZE (60 HZ)
Amana 876.A MWAVE - FAMILY SIZE (60 HZ)
Amana 876.B MWAVE - FAMILY SIZE (60 HZ)
Magic Chef 8770RB SURFACE UNIT- ELE
Magic Chef 8770RV SURFACE UNIT- ELE
Jenn-Air 87848 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87849 RANGE- F/S STD DDRAFT ELE
Jenn-Air 87899 MISC / ACCESSORY
Jenn-Air 87904 ELE CARTRIDGE
Jenn-Air 87914 MISC / ACCESSORY
Jenn-Air 87919 MISC / ACCESSORY
Niagra 8795-0 4000 WATT PORTABLE AC GENERATOR
Magic Chef 87LA-1 SURFACE UNIT- ELE
Magic Chef 87LA-1G SURFACE UNIT- ELE
Magic Chef 87LK-1 SURFACE UNIT- ELE
Magic Chef 87LN-1 SURFACE UNIT- ELE
Magic Chef 87LN-1G SURFACE UNIT- ELE
Magic Chef 87LS-1 SURFACE UNIT- ELE
Magic Chef 87LS-1G SURFACE UNIT- ELE
Hoover 88
Amana 880.000 RANGE- S/C S/I DDRAFT GAS
Amana 880.001 RANGE- S/C S/I DDRAFT GAS
Amana 880.002 MWAVE - FAMILY SIZE (60 HZ)
Amana 880.003 RANGE- S/C S/I DDRAFT GAS
Amana 880.004 RANGE- S/C S/I DDRAFT GAS
Amana 880.110 RANGE- S/C S/I DDRAFT GAS
Amana 880.120 RANGE- S/C S/I DDRAFT GAS
Amana 880.130 RANGE- S/C S/I DDRAFT GAS
Amana 880.130*1 LITTON BUILT-IN WALL OVEN
Amana 880.130x1 RANGE- S/C S/I DDRAFT GAS
Frigidaire 88057-7A CHEST FREEZER
Whirlpool 880652124P0 30" ELECTRIC CERAN FREESTANDING RANGE STANDARD CLEAN OVEN
Frigidaire 88157-7A CHEST FREEZER
Frigidaire 88158-7A CHEST FREEZER
Frigidaire 88158A CHEST FREEZER
Frigidaire 88161-0A FREEZER
Frigidaire 88161-0B FREEZER
Frigidaire 88161-0D FREEZER
Jenn-Air 88168 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88169 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88170 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88186 MISC / ACCESSORY
Frigidaire 88258-7A FREEZER
Frigidaire 88258-7B FREEZER
Frigidaire 88269A CHEST FREEZER
Frigidaire 88269B CHEST FREEZER
Jenn-Air 88353 SURFACE UNIT- ELE
Jenn-Air 88353-8 SURFACE UNIT- ELE
Jenn-Air 88368 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88369 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88370 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88371 RANGE- F/S STD DDRAFT ELE
Jenn-Air 88372 RANGE- F/S STD DDRAFT ELE
Whirlpool 885450 ELECTRIC DRYER
Whirlpool 885453 ELECTRIC DRYER
Whirlpool 885455 ELECTRIC DRYER
Whirlpool 885456 ELECTRIC DRYER
Whirlpool 885457 ELECTRIC DRYER
Whirlpool 885458 ELECTRIC DRYER
Whirlpool 885461 ELECTRIC DRYER
Whirlpool 885462 ELECTRIC DRYER
Whirlpool 885463 ELECTRIC DRYER
Whirlpool 885464 ELECTRIC DRYER
Whirlpool 885465 ELECTRIC DRYER
Whirlpool 885468 ELECTRIC DRYER
Whirlpool 885469 ELECTRIC DRYER
Whirlpool 885472 ELECTRIC DRYER
KitchenAid 885779 SIDE-BY-SIDE REFRIGERATOR
Jenn-Air 88889 SURFACE UNIT- ELE
Jenn-Air 88890 SURFACE UNIT- ELE
Jenn-Air 88891 SURFACE UNIT- ELE
Magic Chef 88FK-1 SURFACE UNIT- ELE
Magic Chef 88FK-2 SURFACE UNIT- ELE
Magic Chef 88FK-6 SURFACE UNIT- ELE
Magic Chef 88FN-2 SURFACE UNIT- ELE
Magic Chef 88FN-6 SURFACE UNIT- ELE
Magic Chef 88LK-6 SURFACE UNIT- ELE
Magic Chef 88LN-6 SURFACE UNIT- ELE
Amana 890.000 RANGE- S/C S/I DDRAFT GAS
Amana 890.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 890.301 MWAVE - FAMILY SIZE (60 HZ)
Amana 890.302 MWAVE - FAMILY SIZE (60 HZ)
Amana 890.304 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 89161-0A FREEZER
Frigidaire 89161-0B FREEZER
Frigidaire 89161-0C CHEST FREEZER
Frigidaire 89257-7A CHEST FREEZER
  #2 (permalink)
Old 12-13-2009, 02:27 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Your model number looks to be short 3 digits at the start, please check it.
Perhaps if the unit has a name other than just Kenmore it will help.
If you have to wait several minutes before you can restart the unit, it could be that the motor's internal thermal cut-off is tripping. Then you have to wait for the motor to cool down and the cut-off to reset before it will start.
This is a puzzler; if it is the motor overheating the timer should still advance in timed dry. Usually the timer gets power directly from half the line in timed dry and this is the same side that runs the main motor.
Cannot say.
You may want to open up the control console and take a look.
With a little luck perhaps the wiring diagram is in there.
Also it may be glued to the back panel.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer starts and shuts off 2 minutes or less argh Dryer Repair 2 11-23-2009 08:35 AM
Dryer Shuts Off After 20 Minutes Of Dry Time carolrmsqt@aol.com Dryer Repair 1 11-23-2009 05:29 AM
gas dryer flame shuts off after minutes binfamily Dryer Repair 1 01-20-2009 04:31 AM
Dryer shuts off after about 10 minutes charysemcdaniel Dryer Repair 1 08-10-2008 07:42 PM
gas dryer shuts off after a couple minutes sharkyhall Dryer Repair 3 01-15-2008 09:44 AM
