Ok I tried the Field mode, but no codes present. It says the unit is working properly.
Burner lights for about 1 minute then goes out. The igniter will glow again but no flame and then it goes out. After a short pause it will try again, then after a few tries, it will light for about 1 minute again. Then the same process starts all over again.
What's going on here???
