Discuss
Dryer will not start
 in
Dryer Repair
Hello. My dryer will not start but the timer is ticking. The inside light is not operating and it used
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer will not start
  #1 (permalink)
Old 03-15-2008, 07:03 PM
roc99 roc99 is offline
Junior Member
roc99 is on a distinguished road
Default Dryer will not start
Model Number: PYE2000AZW   Brand: Maytag   Age: 5 - 10 years
Hello. My dryer will not start but the timer is ticking. The inside light is not operating and it used to work fine too. The door switch tests godd. Any suggestions would be appreciated. Thanks.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-16-2008, 04:20 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
I would pull the dryer apart and check the thermal fuse on the blower housing, a white plastic disk about 1 inch diameter.
__________________
  #3 (permalink)
Old 03-17-2008, 08:31 PM
Junior Member
I have found what appears to be a thermostat control (referring to the schematic) at the blower housing cover. It has 4 wires attatched. There are no other discs or wires there so did you mean this item or is the thermal fuse located elsewhere.
  #4 (permalink)
Old 03-18-2008, 04:45 AM
Senior Expert
APP Volunteer
Default
On this dryer, the thermal fuse is not on the blower housing, so I don't know where it is. It is wired in between the door switch and ground. That should help you find it.
__________________
  #5 (permalink)
Old 03-18-2008, 08:08 AM
abbie abbie is online now
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
I would check first,to see if there is a blown fuse or open breaker there might be only 110 volts going to the dryer.Check your fuse panel there should be 240 volts going to the dryer. It sounds like one off the two fuses are blown.
__________________
  #6 (permalink)
Old 03-18-2008, 08:08 PM
Junior Member
Default
I found the thermal fuse in the area of the heating element housing. Sure enough it had infinite resistance so I replaced it. I also replaced the high limit thermostat as a precaution to not blowing the fuse again, according to the enclosed instruction sheet. The passages were full of old packed lint so the dryer is clean and working great. Thanks very much for the diagnosis as it saved me buying a new one.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer will still not start allyvania Dryer Repair 1 02-12-2008 08:10 PM
Dryer Won't Start COMET 75 Dryer Repair 1 02-12-2008 06:19 PM
Dryer won't start milisa Dryer Repair 0 12-18-2007 07:22 PM
Dryer will not start - sometimes stripe5 Dryer Repair 1 11-26-2007 07:45 PM
Dryer will not start bob38 Dryer Repair 2 09-19-2007 08:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
