| » dryer starting and heating problems |
Odds are you have a bad even heat control.
If your dryer says "Even heat" or "Soft heat" somewhere on the console, you have a bad even heat control. The even heat control not only controls the heat, but it also engages the motor relay. That is why you have to hold the start button. Matt |
Yup, it is a circuit board under the console. Remove the two philips screws at the front bottom of the console. The console flips up and the board is in the center behind the console.
When you order the even heat control, you may get a small harness and relay with the kit. Follow the instructions. It is not hard to do if you are familiar with simple hand tools. Matt |
Hi jbcholding,
In addition to Matt, if you would like the right part number for the control board we need the complete model number of the dryer. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
| Display Modes | |
| dryer not starting - light come on not starting | mike31 | Dryer Repair | 1 | 01-11-2010 07:50 PM |
| Dryer heating without starting | dpeterson4150 | Dryer Repair | 1 | 06-16-2009 05:43 PM |
| Gas Dryer Starting Problems | Paul1720 | Dryer Repair | 5 | 03-19-2008 02:49 PM |
| Heating Problems | Ms. Irish | Dryer Repair | 1 | 12-14-2007 11:31 AM |
| Heating problems | dharer | Oven Repair (including Ranges and Cooktops) | 0 | 08-22-2007 09:00 AM |
