Discuss
Dryer heats but takes several cycles to dry.
 in
Dryer Repair
I checked dryer exhaust all the way to outside (about 30 feet) and it is reasonably clear. I used the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer heats but takes several cycles to dry.
  #1 (permalink)
Old 03-14-2008, 11:05 AM
cos1954 cos1954 is offline
Junior Member
cos1954 is on a distinguished road
Default Dryer heats but takes several cycles to dry.
Model Number: GEW9200LW1   Brand: Whirlpool   Age: 1 - 5 years
I checked dryer exhaust all the way to outside (about 30 feet) and it is reasonably clear. I used the troubleshooting guide provided with the dryer. I got to the section that has you check resistance on two pins on the moisture sensor connector. I have been unable to remove connector from moisture sensor to check resistance. Does connector require a special tool? I tried squeezing the tabs on either side and pulling, but with needle nose, it isn't working.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
My dryer takes several cycles to dry clothes alvarez Dryer Repair 2 12-17-2007 09:15 AM
Dryer heats a little but thats all garocker Dryer Repair 3 12-01-2007 10:36 AM
Dryer takes two cycles to dry SlowGin Dryer Repair 3 11-09-2007 02:14 AM
Dryer heats sometimes TommyC Dryer Repair 1 10-27-2007 01:44 PM
dryer heats but not hoy danandlisa1 Dryer Repair 0 10-09-2007 03:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
