Discuss
Dryer Will Not Heat
 in
Dryer Repair
My dryer will not heat. I checked the jumper wire and it is ok. What is the most common problem?
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Will Not Heat
  #1 (permalink)
Old 12-06-2009, 12:40 PM
Junior Member
randyhensley is on a distinguished road
Default Dryer Will Not Heat
Model Number: MDE8400AYW   Brand: Maytag   Age: 5 - 10 years
My dryer will not heat. I checked the jumper wire and it is ok. What is the most common problem? Heating Element, Hi Lo Limit Thermostat or Thermal Fuse?
Randy
Related Models
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
Maytag MDE9806AZW DRYER- ELE
Maytag MDE9876AYW DRYER- ELE
Maytag MDET236AYW DRYER- ELE
Maytag MDET236AZW DRYER- ELE
Maytag MDET336AYW DRYER- ELE
Maytag MDET336AZW DRYER- ELE
Maytag MDET446AYW DRYER- ELE
Maytag MDET446AZW DRYER- ELE
Maytag MDG100PN1 MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1L MANUAL, PARTS (DRYER GAS)
Maytag MDG100PN1W MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSAKL MAYTAG COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MDG10CSEGL MANUAL, PARTS (DRYER GAS)
Maytag MDG10CSEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10DAABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10MNAAW MANUAL, PARTS (DRYER GAS)
Admiral MDG10MNAGW DRYER- GAS
Maytag MDG10MNEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDABL MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDABW MANUAL, PARTS (DRYER GAS)
Maytag MDG10PDEGL MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG10PDEGW MANUAL, PARTS (EXPORT) (DRYER ELE)
Maytag MDG10PSABW MANUAL, PARTS (DRYER ELE)
Maytag MDG10PSAGL MAYTAG LAUNDRY (DRYER ELE)
Maytag MDG10PSAGW MAYTAG LAUNDRY (DRYER ELE)
Frigidaire MDG116RBW0 Frg(v1) / 27 " Gas Dryer
Frigidaire MDG116RBW1 Frg(v0) / Gas Dryer
Maytag MDG11CSAAL MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSAAW MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSABW MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSAGL MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSAGW MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSEGL MANUAL, PARTS (DRYER GAS)
Maytag MDG11CSEGW MANUAL, PARTS (DRYER GAS)
Maytag MDG11MNAAW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG11MNAGW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG11MNEGW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG11PDAAL MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDAAW MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDABL MAYTAG LAUNDRY (DRYER GAS)
Maytag MDG11PDABW MAYTAG LAUNDRY (DRYER GAS)
  #2 (permalink)
Old 12-07-2009, 05:14 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG MDE8400AYW Dryer - Ele | AppliancePartsPros.com
Here is a manual, note it is for similar models not this specific model.
http://www.servicematters.com/maytag...s/16023110.pdf
Not sure what you mean by jumper wire.
Heating Element - this would be at the top of the list
Hi Lo Limit Thermostat - also a possibility along with the cycling thermostat.
Thermal Fuse - not possible as the fuses in this unit kill power to the motor
First try flipping the breaker off/on slowly a couple times, sometimes it can loose half the line without actually tripping the breaker and the heater requires the full 240 volts. Better yet measure it at the plug
L1 to L2 should be 240 volts
Also unplug the unit and check the wiring at the unit's terminal block to ensure a wire has not burned off.
Next unplug the unit and check the heating coil.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
