Discuss
dead dryer - Maytag
 in
Dryer Repair
My dryer was working fine 2 hours ago. Now it won't do anything. no reponse from any button or knob.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » dead dryer - Maytag
  #1 (permalink)
Old 12-05-2009, 01:28 PM
Junior Member
leeandbrande is on a distinguished road
Default dead dryer - Maytag
Model Number: HYE3658AYW   Brand: Maytag   Age: 1 - 5 years
My dryer was working fine 2 hours ago. Now it won't do anything. no reponse from any button or knob. No interior light when door is open. I have verified power to the outlet and to the terminal inside the dryer. What next?
Ads By Google
Related Models
Maytag HYE3658AYW Dryer - Ele
Maytag HYE3658AZS Dryer - Ele
Maytag HYE3658AZW Dryer - Ele
Maytag HYG2460AWW Dryer - Gas
Maytag HYG3460AWW Dryer - Gas
Maytag HYG3657AWW Dryer - Gas
Maytag HYG3658AWW Dryer - Gas
Amana HZ1070 Dryer - Ele
Amana I2000 Mwave - Family Size (60 Hz)
Whirlpool IACS50
Whirlpool IACS501
Whirlpool IACS50E
Whirlpool IACS50E1
Whirlpool IAS5000RQ0 Automatic Washer
Whirlpool IAS5000RQ1 Automatic Washer
Whirlpool IAS5000RQ2 Automatic Washer
Whirlpool IAX4000RQ0 Automatic Washer
Whirlpool IAX4000RQ1 Automatic Washer
Whirlpool IAX4000RQ2 Automatic Washer
Whirlpool IBD550PRS00 30" Built - in Electric Double Oven Self Clean Thermal Convection
Whirlpool IBD550PRS02 30" Built - in Electric Double Oven Self Clean Thermal Convection
Whirlpool IBS124PSS00 24" Built - in Electric Oven Convection
Whirlpool IBS224PSM00 24" Built - in Electric Oven Convection
Whirlpool IBS324PSW00 24" Built - in Electric Oven Convection
Whirlpool IBS330PRS01 30" Built - in Electric Oven Self Clean
Whirlpool IBS330PRS02 30" Built - in Electric Oven Self Clean
Whirlpool IBS550PRQ00 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRQ01 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRQ02 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS00 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS01 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS02 30" Built - in Electric Oven Self Clean Thermal Convection
Whirlpool IBS550PRS03 30" Built - in Electric Oven Self Clean Thermal Convection
Amana IC-2 Ref - Top Mount
Amana IC-3H Ref - Top Mount
Amana IC2 Misc / Accessory
Amana IC3 Misc / Accessory
Amana IC3H Misc / Accessory
Amana IC3K Misc / Accessory
Amana IC3N Misc / Accessory
Amana IC3Q Misc / Accessory
Amana IC4 Misc / Accessory
Amana IC4N Misc / Accessory
Amana IC4Q Misc / Accessory
Amana IC4R Misc / Accessory
Amana IC52 Misc / Accessory
Whirlpool IC5E
Amana IC6 Misc / Accessory
Maytag ICE Misc / Accessory
International ICE-25 Misc / Accessory
International ICE-26 Misc / Accessory
Admiral ICES24F9 Ref - SXS/I&W
Admiral ICES24F9A Ref - SXS/I&W
Admiral ICES24F9H Ref - SXS/I&W
Admiral ICNF17E8 Freezer - Vertical
Admiral ICNS22F9 Ref - SXS/I&W
Admiral ICNS22F9A Ref - SXS/I&W
Admiral ICNS22F9H Ref - SXS/I&W
Admiral ICNS24F9 Ref - SXS/I&W
Admiral ICNS24F9A Ref - SXS/I&W
Admiral ICNS24F9H Ref - SXS/I&W
Admiral ICNS28D9 Ref - SXS/I&W
Admiral ICNS28D9- Ref - SXS/I&W
Admiral ICNS28D92 Ref - SXS/I&W
Admiral ICNS28D92A Ref - SXS/I&W
Admiral ICNS28D92H Ref - SXS/I&W
Admiral ICNS28D9A Ref - SXS/I&W
Admiral ICNS28D9F Ref - SXS/I&W
Admiral ICNS28D9H Ref - SXS/I&W
Admiral ICNT18F9L Ref - Top Mount/ I&W
Admiral ICNT18F9LA Ref - Top Mount/ I&W
Admiral ICNT18F9LH Ref - Top Mount/ I&W
Admiral ICNT22F93 Ref - Top Mount/ I&W
Admiral ICNT22F93A Ref - Top Mount/ I&W
Admiral ICNT22F93H Ref - Top Mount/ I&W
Admiral ICNT22F9L Ref - Top Mount/ I&W
Admiral ICNT22F9LA Ref - Top Mount/ I&W
Admiral ICNT22F9LH Ref - Top Mount/ I&W
Whirlpool ICR410RB00 30" Electric Ceran Built - in Cooktop
Whirlpool ICR410RB01 30" Electric Ceran Built - in Cooktop
Whirlpool ICR410RP01 30" Electric Ceran Built - in Cooktop
Whirlpool ICR416RB00 36" Electric Ceran Built - in Cooktop
Whirlpool ICR416RB01 36" Electric Ceran Built - in Cooktop
Whirlpool ICR416RP00 36" Electric Ceran Built - in Cooktop
Whirlpool ICR416RP01 36" Electric Ceran Built - in Cooktop
Whirlpool ICS300RQ00 30" Gas Cooktop
Whirlpool ICS300RQ01 30" Gas Cooktop
Whirlpool ICS300RQ02 30" Gas Cooktop
Whirlpool ICS300RS00 30" Gas Cooktop
Whirlpool ICS300RS01 30" Gas Cooktop
Whirlpool ICS300RS02 30" Gas Cooktop
Whirlpool ICS304SM00 30" Gas Cooktop
Whirlpool ICS306RS00 36" Gas Cooktop
Whirlpool ICS306RS01 36" Gas Cooktop
Whirlpool ICS404SB00 30" Gas Cooktop
Whirlpool ID2GFGXRS00 Refrigerator
Whirlpool ID2GFGXRS01 Refrigerator
Whirlpool ID2HHEXTS00 Refrigerator
Whirlpool ID2HHEXTS01 Refrigerator
Whirlpool ID5GFGXRQ00 Refrigerator
Whirlpool ID5GFGXRQ01 Refrigerator
Whirlpool ID5GFGXRQ02 Refrigerator
  #2 (permalink)
Old 12-06-2009, 02:19 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here are your parts has a wiring diagram.
Replacement parts for MAYTAG HYE3658AYW Dryer - Ele | AppliancePartsPros.com
I am assuming that when you checked for power you checked the 240 volts and also the 2 - 120 volts to Neutral.
Sounds like the thermal fuse is blown, Item 5 in section 5.
I would also replace the hi-limit thermostat as that should have regulated the temperature to ensure the fuse did not blow.
There is a scenario where the hi-limit does not have to be replaced re: a grounded element. Remove both wires from the heater and check it with a meter, Should be approximately 12 ohms.
Then measure from each connector to the case/frame, both should be infinite ohms (open).
If not you have a grounded element and it can over heat without control from the thermostats.
If the heater is OK
Then you have to find out what caused the heater to overheat.
The most common cause is a dirty or malfunctioning vent system.
Also could be a broken belt, bad drum seals, bad filter assembly to blower seal, dirty or loose blower wheel, dirty lint filter or it is coated with fabric softener residue.
Basically anything that impedes/reduces the air flow over the heating coils.
__________________
  #3 (permalink)
Old 12-06-2009, 11:13 AM
Junior Member
Default
Thanks for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Admiral Dryer Dead Rfunaro Dryer Repair 6 09-29-2010 09:49 PM
Maytag clock dead Liddie Oven Repair (including Ranges and Cooktops) 0 01-17-2010 01:15 PM
maytag performa pyet344ayw dryer, dead.....AGAIN! noble26 Dryer Repair 1 12-10-2009 07:53 AM
Maytag dishwasher dead WA_BELL1 Dishwasher Repair 1 05-31-2009 02:17 PM
Maytag microwave dead WarMar Microwave Repair 3 01-08-2009 03:30 PM
