| » dyer belt GE |
Model Number: dbxr463ed1ww Brand: GE Age: 1 - 5 years
Skid plates went bad, replaced and wanted to change belt also but having a problem not understanding why there isn't enough tension on belt/drum? I've look for a spring mechanizm, but no luck on that and when I took it apart I started on the top-side and never once gave it a thought to look underneath everything to actually check the tension stamatic. Can someone please advise me if there is any spring, which I have tripled check, nothing. It's a very easy design but don't want to put it all back together with out any tension for sure on the belt and then have to tear into it all again. Please e-mail me at stitzelk40@yahoo.com
Thanks, Stits |
Hi Stits,
The belt tension provided by the idler pulley (#216 on the break down diagram). You can find a schematic of the belt goes around the idler pulley and the motor pulley attached to the thread. Here are the break down diagrams for the GE dryer with the model number similar to yours Model DBXR463EB0CC Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| Dyer stopped, won't start | proberson | Dryer Repair | 3 | 03-17-2008 08:24 PM |
| maytag washer/dyer combo | jeff wagner | Washer Repair | 6 | 02-19-2008 10:32 AM |
| belt | sodell | Washer Repair | 1 | 01-07-2008 11:13 AM |
| Estate Dyer making grinding noise | gsaldana71 | Dryer Repair | 1 | 12-28-2007 01:17 PM |
| gas dyer will not heat | tomfreez3@sbcglobal.net | Dryer Repair | 1 | 12-11-2007 02:21 PM |
