dryer spins air flows no heat already replaced thermostat and element still no heat help clueless
Originally Posted by: gvalmom1 dryer spins air flows no heat already replaced thermostat and element still no heat help clueless what else can it be i am not a pro but need my dryer badly have four teen age kids:confused:
Test the outlet with a meter - you need 240v to run the heater. if you are only getting half of that then try flipping the breaker and that will usually reset it.
