Discuss
Maytag Neptune only dries on air fluff
 in
Dryer Repair
Hi! I'm hoping someone can help me out the dryer goes through the regular cycle when I dry (spins and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Neptune only dries on air fluff
  #1 (permalink)
Old 12-03-2009, 04:48 PM
Junior Member
Maldonado316 is on a distinguished road
Default Maytag Neptune only dries on air fluff
Model Number: MDE6700AYW   Brand: Maytag   Age: 1 - 5 years
Hi! I'm hoping someone can help me out the dryer goes through the regular cycle when I dry (spins and everything) except the clothes are still wet like if I never turned it on. I use the fluff cycle (a couple of times at 99 minutes) and the clothes get dry. Any ideas? My grandpa seems to think the heating element core without having seen it.
Maytag Neptune
Purchased: February 2007
Model #: MDE6700AYW
Related Models
Maytag MDE6700AYW DRYER- ELE
Maytag MDE6700AZW DRYER- ELE
Maytag MDE6800AYQ DRYER- ELE
Maytag MDE6800AYW DRYER- ELE
Maytag MDE6800AZQ DRYER- ELE
Maytag MDE6800AZW DRYER- ELE
Maytag MDE7057AYQ DRYER- ELE
Maytag MDE7057AYW DRYER- ELE
Maytag MDE7057AZW DRYER- ELE
Maytag MDE7400AYQ DRYER- ELE
Maytag MDE7400AYW DRYER- ELE
Maytag MDE7400AZQ DRYER- ELE
Maytag MDE7400AZW DRYER- ELE
Maytag MDE7460AYQ DRYER- ELE
Maytag MDE7460AYW DRYER- ELE
Maytag MDE7500AYQ DRYER- ELE
Maytag MDE7500AYW DRYER- ELE
Maytag MDE7500AZQ DRYER- ELE
Maytag MDE7500AZW DRYER- ELE
Admiral MDE7550AGW DRYER- ELE
Maytag MDE7600AUW DRYER- ELE
Maytag MDE7600AYQ DRYER- ELE
Maytag MDE7600AYW DRYER- ELE
Maytag MDE7600AZQ DRYER- ELE
Maytag MDE7600AZW DRYER- ELE
Maytag MDE7657AYQ DRYER- ELE
Maytag MDE7657AYW DRYER- ELE
Maytag MDE7657BYQ DRYER- ELE
Maytag MDE7657BYW DRYER- ELE
Maytag MDE7658AYQ DRYER- ELE
Maytag MDE7658AYW DRYER- ELE
Maytag MDE7658BYQ DRYER- ELE
Maytag MDE7658BYW DRYER- ELE
Maytag MDE7757AYQ DRYER- ELE
Maytag MDE7757AYW DRYER- ELE
Maytag MDE7758AYQ DRYER- ELE
Maytag MDE7758AYW DRYER- ELE
Maytag MDE8000AYQ DRYER- ELE
Maytag MDE8000AYW DRYER- ELE
Maytag MDE8000AZW DRYER- ELE
Maytag MDE8057AYQ DRYER- ELE
Maytag MDE8057AYW DRYER- ELE
Maytag MDE8057AZW DRYER- ELE
Maytag MDE8058AYQ DRYER- ELE
Maytag MDE8058AYW DRYER- ELE
Maytag MDE8400AYQ DRYER- ELE
Maytag MDE8400AYW DRYER- ELE
Maytag MDE8400AZW DRYER- ELE
Maytag MDE8416AYA DRYER- ELE
Maytag MDE8416AYW DRYER- ELE
Admiral MDE8426AAW DRYER- ELE
Admiral MDE8426AGW DRYER- ELE
Maytag MDE8500AYW DRYER- ELE
Maytag MDE8506AYA DRYER- ELE
Maytag MDE8506AYW DRYER- ELE
Maytag MDE8506AZW DRYER- ELE
Admiral MDE8550AGW DRYER- ELE
Admiral MDE8550BGW DRYER- ELE
Maytag MDE8600AYQ DRYER- ELE
Maytag MDE8600AYW DRYER- ELE
Maytag MDE8600AZQ DRYER- ELE
Maytag MDE8600AZW DRYER- ELE
Maytag MDE8757AYQ DRYER- ELE
Maytag MDE8757AYW DRYER- ELE
Maytag MDE9206AYA DRYER- ELE
Maytag MDE9206AYW DRYER- ELE
Maytag MDE9206AZW DRYER- ELE
Maytag MDE9306AUW DRYER- ELE
Maytag MDE9306AYA DRYER- ELE
Maytag MDE9306AYW DRYER- ELE
Maytag MDE9306AZA DRYER- ELE
Maytag MDE9306AZW DRYER- ELE
Maytag MDE9316AYA DRYER- ELE
Maytag MDE9316AYQ DRYER- ELE
Maytag MDE9316AYW DRYER- ELE
Maytag MDE9316AZW DRYER- ELE
Maytag MDE9357AYA DRYER- ELE
Maytag MDE9357AYW DRYER- ELE
Maytag MDE9360AYW DRYER- ELE
Maytag MDE9390AYW DRYER- ELE
Maytag MDE9390AZW DRYER- ELE
Maytag MDE9420AYW DRYER- ELE
Maytag MDE9420AZW DRYER- ELE
Maytag MDE9520AYQ DRYER- ELE
Maytag MDE9520AYW DRYER- ELE
Maytag MDE9520AZW DRYER- ELE
Maytag MDE9557AYA DRYER- ELE
Maytag MDE9557AYQ DRYER- ELE
Maytag MDE9557AYW DRYER- ELE
Maytag MDE9557AZA DRYER- ELE
Maytag MDE9557AZQ DRYER- ELE
Maytag MDE9557AZW DRYER- ELE
Maytag MDE9606AUW DRYER- ELE
Maytag MDE9606AYA DRYER- ELE
Maytag MDE9606AYQ DRYER- ELE
Maytag MDE9606AYW DRYER- ELE
Maytag MDE9606AZA DRYER- ELE
Maytag MDE9606AZQ DRYER- ELE
Maytag MDE9606AZW DRYER- ELE
Maytag MDE9700AYM DRYER- ELE
Maytag MDE9700AYW DRYER- ELE
Maytag MDE9700AZM DRYER- ELE
Maytag MDE9700AZW DRYER- ELE
Maytag MDE9706AYA DRYER- ELE
Maytag MDE9706AYW DRYER- ELE
Maytag MDE9706AZW DRYER- ELE
Maytag MDE9766AYW DRYER- ELE
Maytag MDE9766AZW DRYER- ELE
Maytag MDE9800AYQ DRYER- ELE
Maytag MDE9800AYW DRYER- ELE
Maytag MDE9800AZQ DRYER- ELE
Maytag MDE9800AZW DRYER- ELE
Maytag MDE9806AYA DRYER- ELE
Maytag MDE9806AYW DRYER- ELE
Maytag MDE9806AZW DRYER- ELE
Maytag MDE9876AYW DRYER- ELE
Maytag MDET236AYW DRYER- ELE
Maytag MDET236AZW DRYER- ELE
Maytag MDET336AYW DRYER- ELE
Maytag MDET336AZW DRYER- ELE
  #2 (permalink)
Old 12-04-2009, 07:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for MAYTAG MDE6700AYW Dryer - Ele | AppliancePartsPros.com
Here is a tech sheet and a manual and a bulletin which may apply
http://www.servicematters.com/maytag...s/16026881.pdf
http://www.servicematters.com/maytag...s/16025911.pdf
http://www.servicematters.com/maytag...TDL-0141-B.pdf
I am assuming that if you run the unit for a couple 99 minute cycles the clothes will dry independent of cycle type though the above seems to indicate that the clothes will never dry on any cycle other than a Fluff which would be very weird.
Grandpa may be correct and since I have 5 grandchildren I just naturally feel I should side with him.
You could try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
If this does nothing I would check it at the plug
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral, both should be 120 volts
If OK
Try the diagnostics to see if it will help narrow the cause down.
If OK or inconclusive
Open the unit up and check the heating coil, should be approximately 10 ohms.
If OK
Check the thermostats in the heater circuit, all should be 0 ohms
If OK
Check the thermistor and the moisture sensor
If OK
Odds are high that the control board is shot.
__________________
  #3 (permalink)
Old 12-04-2009, 01:59 PM
Junior Member
FixYa2 is on a distinguished road
Thumbs down No Heat Neptune Dryer #DDE 5500AYW
Me too!
Friend took off plug-in wire back panel.(3)Wires.(2) "burned-a-part".(1) "burned" still slightly attached.(2) were what caused "heating".(1) wire caused "power to dryer", why it still runs and blows cold air!!! Repairman said "SIMPLY" the wires were not screwed on tight enough to back panel!!!
What do I do now? For $50.00 repairman will come out and look-see. Delima: (1) chuck $1,000 dryer, because many weeks delay?, wrong parts, try something else?, more money, moremoney, more money? -or- (2) Go get used $75 dryer and do laundry now!
FixYa2....
  #4 (permalink)
Old 12-06-2009, 03:38 AM
Senior Expert
APP Volunteer
Default
FixYa2
Please start your own thread using in this section "POST NEW TOPIC"
Hijacking another person's when you have a different problem and a different machine will just confuse things
thanks
Denman
__________________
  #5 (permalink)
Old 12-10-2009, 08:39 AM
Junior Member
Default
Thanks for the reply denmen, i'll give those a try
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Neptune jsinchi Dryer Repair 0 10-19-2009 09:56 AM
dryer burns clothes even on air fluff phitter38 Dryer Repair 1 08-12-2009 08:37 AM
maytag neptune bull Washer Repair 0 03-28-2009 04:44 PM
Maytag Neptune imjrm Washer Repair 1 03-18-2009 05:52 PM
Dryer Dries To Slow Javier Dryer Repair 2 08-21-2007 07:35 PM
