Appliance Repair Forum
-   Dryer Repair (http://forum.appliancepartspros.com/dryer-repair/)
-   -   Amana LEM847W won't heat! (http://forum.appliancepartspros.com/dryer-repair/61732-amana-lem847w-wont-heat.html)
gbeck04 12-01-2009 04:46 PM
My Dryer tumbles but won't heat. I've checked the circuit breaker box. It's okay. It shouldn't be the thermal fuse because that would stop the motor from running. So I believe it's either the thermostat, Heater, or Heating element. So here is where I"m at.
Okay, I've got my dryer disassembled and have the drum out and can see the thermostat. Where is the heating element and how can you tell if it is broken? How exactly do I check to see if the thermostat isn't working? If I replace the thermostat do I have to replace the Heater, thermostat, part#AP4070513 and the thermostat part#AP4291810. or just one or the other?
Thanks,
GB
denman 12-02-2009 04:23 AM
Replacement parts for AMANA LEM847W Dryer - Ele | AppliancePartsPros.com
Did you flip it off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Better yet measure it with a meter at the plug
L1 to L2 should be 240 volts
I could not find a wiring diagram for this unit so cannot say. You only have one thermal fuse and on many units it only removes power from the heater.
See section 6. There is the heater, the thermal fuse and the hi-limit thermostat.
Remove both wires from the heater and measure it with a meter, should be approximately 10 ohms. Also measure from each heater connector to the case, this checks for a grounded element, both should be infinite ohms (open)
Remove one wire from the thermal fuse and measure it, should be 0 ohms.
If open replace both the fuse and the hi-limit thermostat as the hi-limit should have regulated the heat so that the fuse did not blow. Odds are high that it's contacts are welded together.
Remove one wire from the hi-limit thermostat and check it, should be 0 ohms.
Same applies to the operating thermostat on the blower housing.
Be sure to put the wires back on the components right after you take your measurements so you do not mix them up.
Also if the fuse is blown check all internal seals (drum etc.), check/clean the blower wheel and clean/check your vent system.
You may as well check the rear support rollers, front glides, idler wheel and belt for wear and replace as necessary.
