I actually don't know brand/model as i sit at my desk at work, but this is a general question; the dryer operates on propane; after several loads noticed a strong gas smell in nearby room, same smell inside dryer bin. Had the propane company check the line and tank, there is no leak in the pipe or tank. When the dryer was turned on for a test, no odor. Propane comany said it could be there is a problem with dyer's propane valve? Do I wait until I smell this again (PS the propane source is currently turned off ) or call in for a repair (PS NO WAY CAN I DO THIS MYSELF, much too frady scared)
