Discuss
Dde7900sblww
 in
Dryer Repair
Dryer will not start, I replaced the rotary start switch, it worked for 3 times, then quit again. Should I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dde7900sblww
  #1 (permalink)
Old 12-01-2009, 11:06 AM
Junior Member
kagey5148 is on a distinguished road
Default Dde7900sblww
Brand: GE   Age: 5 - 10 years
Dryer will not start, I replaced the rotary start switch, it worked for 3 times, then quit again. Should I replace the resistor next or could it be something else? could you give me a ballpark figure to repair this machine?
Thank you
kagey5148
Ads By Google
  #2 (permalink)
Old 12-02-2009, 05:18 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Blower & drive assembly replacement parts for General Electric DDE7900SBLWW Electric dryer | AppliancePartsPros.com
Here is a good link. Check out #28 which may help some with the wiring
http://www.applianceaid.com/ge-dryers.html
Hopefully you have the wiring diagram, it is usually in the control console.
I will not be able to find the diagram for this unit on the net as GE likes to keep all tech info a secret. Guess it keeps their techs busy.
No, as far as I know the resistor has nothing to do with starting the unit.
No idea till you figure out what the cause is.
First check that the unit is getting the correct power.
Next high on the list would be a broken belt as the unit does have a belt/idler switch which probably cuts power to the motor.
Then perhaps a thermal fuse if there is one in the motor's circuit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
