Discuss
Frigidaire dryer turns but no heat
 in
Dryer Repair
Dryer works on "no heat" setting. On any heat setting the motor runs for less than a second, then the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire dryer turns but no heat
  #1 (permalink)
Old 11-27-2009, 12:11 PM
Junior Member
MartinF is on a distinguished road
Default Frigidaire dryer turns but no heat
Model Number: FEQ1442CES0   Brand: Frigidaire   Age: 1 - 5 years
Dryer works on "no heat" setting. On any heat setting the motor runs for less than a second, then the machine closes down, and the panel lights flash "95". The manufacturers test sequence gives the error code "9E". Neither of these codes is in the error code list. The control thermistor, high-limit thermostat, & thermal limiter all check OK. In any case, I don't think they would produce the behaviour described. Any Ideas? The heater is 240V, 4500W. What should its cold resistance be?
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 11-28-2009, 04:47 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Any ideas?
I did find a reference to an E9E error on a unit with a digital display.
It was a low voltage or intermittent voltage error.
Found a couple folks who had this
One was a bad wire in their house wiring.
The other was a short at the control board to the frame.
Resistance should be approximately 12.8 ohms
FYI formula is:
R= E2/P
Resistance equals voltage squared divided by watts
Remove both wires from the heater and check it's resistance.
Then check from each heater terminal to the frame/case, both should be infinite ohms. If not you have a grounded element.
__________________
  #3 (permalink)
Old 01-20-2010, 12:20 PM
Junior Member
Default Solution
Thanks Denman. The error code 95 I quoted was in fact 9E. Iread the flashing lights wrong. Additional symtom: the terminal of the heater relay on the main control board had overheated and started melting the plastic. I changed the main control board (cost 200$!) and it works.
  #4 (permalink)
Old 01-20-2010, 06:37 PM
Senior Expert
APP Volunteer
Default
You are welcome
And thank you for getting back to us now your post will help others who search this forum.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clothes Dryer Heat Turns On/Won't Stay On rmcnutt Dryer Repair 2 11-24-2009 11:55 AM
Gas Dryer won't heat and turns back on bombersdryer Dryer Repair 0 11-21-2009 01:25 PM
dryer turns on but timer not turning and no heat ljv2008 Dryer Repair 8 05-13-2009 08:03 PM
Dryer timers runs until heat turns on goalie66 Dryer Repair 8 01-03-2008 04:20 PM
Dryer doesn't heat while drum turns IMTSam Dryer Repair 0 12-03-2007 08:36 AM
