Discuss
Same dryer, now no heat ***
 in
Dryer Repair
Same kenmore dryer, different problem. She won't heat up now. Runs but no heat. Maybe I should keep this dryer
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Same dryer, now no heat ***
  #1 (permalink)
Old 03-06-2008, 01:55 PM
Junior Member
Single Mom is on a distinguished road
Unhappy Same dryer, now no heat ***
Same kenmore dryer, different problem. She won't heat up now. Runs but no heat. Maybe I should keep this dryer on a dolly for a few months? They say stuff like this runs in 3's. Any help appreciated
Ads By Google
  #2 (permalink)
Old 03-07-2008, 04:52 PM
Expert
APP Volunteer
roycreamer is on a distinguished road
Default
make sure you have 220 volts ... if you only have 110 the dryer will run but not heat... or else you knocked a wire off getting the screwdriver out of the lint filter.... check it out.
__________________
roy
the appliance whisperer
  #3 (permalink)
Old 03-07-2008, 05:46 PM
Junior Member
Default
hope i am checking the outlet correctly. Its a 4 prong it has a (L) at the top 2 (l )one either side and a (O) at the bottom. I checked one side and the bottom, and the other side and the bottom. only have 120 on right side.......nothing on left. 30 amp Breaker didnt trip off. Reset it anyway........still same reading
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
