| » GE dryer timer wont work on automatic setting |
Usually the timer in Auto mode gets power through the heating element when the element is shut off by a thermostat.
Many GE's use 2 elements perhaps one of them is burned out. Also if you have a grounded element (element has broken or sagged and is touching the case), it will never shut off so you never get timer advance. Unplug the unit. Remove the wires from the heating coils. Measure the coils usually around 10 ohms. Then measure from each soil connector to the frame , all should be infinite ohms (open). If not you have a grounded element.
__________________
| Display Modes | |
| Maytag Dryer Automatic Setting - Keeps Running | Robert W. Thomas | Dryer Repair | 6 | 11-16-2011 09:01 AM |
| Dryer wont heat up and timer cycles dont work. | ggordon007 | Dryer Repair | 0 | 08-03-2009 06:47 AM |
| Dryer timer wont advance in automatic mode | player4 | Dryer Repair | 1 | 02-07-2009 03:24 AM |
| clothes dryer wont heat timer wont work | tampee | Dryer Repair | 2 | 01-17-2009 09:53 AM |
| Dryer Timer will not advance in Automatic | kabgreen | Dryer Repair | 2 | 05-10-2008 07:47 PM |
