Whirlpool Duet F26
My Dryer wont start :(
Diagnostic test gives an F26. The element is visibly broken & needs to be replaced. What else should I look at/replace before I order this element? |
Replacement parts for WHIRLPOOL WED8300SW0 | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...%208572759.pdf Unplug the unit for 20 minutes or so. Then give it a try to see if the error still comes up. If it runs OK but just does not have heat I would just order the heater. If the error still occurs. Run the diagnostics as shown in the tech sheet. |
