| » dryer does not stop |
Model Number: 96273100 Brand: Kenmore Age: 5 - 10 years
The dryer seems to work fine on the timed status except it does not stop running. The clothes are dry and goes thru the cooldown period but continues to run until stopped by opening the door.can it be anything otherthan the timer ?
Related Models |
It is possibly your putsh to start switch, particularly if it comes back on after you close the door. Unfortunately it is rather than expensive part but you will have to try it to test out.
Part number: AP2997390
__________________
If it is only doing this on the timed cycle and it does shut off when you open the door even in the middle of the cycle and not start up when you close the door then the timer becomes the likely suspect.
__________________
| Display Modes | |
| Dryer just stop | Patients | Dryer Repair | 4 | 09-01-2009 06:13 AM |
| Dryer does not Stop! | familylaundry | Dryer Repair | 2 | 07-29-2009 04:22 PM |
| Dryer does not stop | dherrick | Dryer Repair | 6 | 04-23-2009 04:58 PM |
| dryer will not stop | freemans | Dryer Repair | 0 | 09-06-2008 10:42 PM |
| Dryer Won't Stop | caligal64 | Dryer Repair | 11 | 12-07-2007 08:29 PM |
