| » loud squeaky rubbing noise |
Model Number: dpsr475ew1ww Brand: GE Age: 5 - 10 years
Dryer making this loud rubbing noise - other things i've seen posted seem to indicate one or all of the following need to be replaced: drum felt, all 4 drum glides, rear drum bearing kit and front drum bearing.
i can see the drum glides are totally worn, the felt is old and no longer goes all the way around the front drum bearing and two spots on the front drum bearing are so worn that the glides are completely gone and i don't think new ones would even fit into the slots due to the wear. seems obvious that i need the felt, glides and front drum bearing. anyone disagree? lastly i removed the rear drum bearing and it doen't look to bad - how do i know if that must be replaced too? i assume these are the repacement parts: Front drum bearing - AP3790641 Dryer drum slide (2) - AP2041815 Slide, drum (2) - AP631382 Felt - AP4319934 if necessary: Bearing kit - AP2619300 Advice? thanks in advance tdotes Ads By Google Related Models |
Your rear bearing is probably ok, but since you are doing a big maintenance overhaul I would replace it. Some folks recommend replacing the idler and the belt, but if they are ok I usually do not do so.
By replacing the bearing you should be good to go for a long time, and not have to be bothered getting into the machine again. Also, be sure and clean out all the lint and dust and dirt while you have it open, particularly in the vent in the front panel.
__________________
| Display Modes | |
| Horrible Loud Squeaky Noise from Dryer | crussell01 | Dryer Repair | 1 | 12-19-2009 06:00 AM |
| Loud Squeaky Dryer Noise | Hart1092 | Dryer Repair | 1 | 11-10-2009 03:28 AM |
| Loud rubbing noise in spin mode | seeyoujimmy | Washer Repair | 3 | 03-28-2009 02:04 PM |
| dryer makes loud squeaky noise | ej1954 | Dryer Repair | 0 | 09-01-2008 07:52 AM |
| Loud squeaky noise from dryer | PeggyS | Dryer Repair | 2 | 03-23-2008 10:21 AM |
