Discuss
Dryer want start but moter hums
 in
Dryer Repair
Dryer was running, I opened door to check on load. When I tried to restart the motor just hums when
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer want start but moter hums
  #1 (permalink)
Old 03-03-2008, 09:12 AM
Junior Member
Dallas Adkins is on a distinguished road
Default Dryer want start but moter hums
Model Number: DLB333EB4WW   Brand: GE   Age: 1 - 5 years
Dryer was running, I opened door to check on load. When I tried to restart the motor just hums when I turn the start knob. I checked the voltage where the pig tail connects to the dryer and have 110 volts on each leg. I removed the belt and the same thing the motor just hums.
Related Models
General Electric DLB3400SBLAD Electric dryer
General Electric DLB3400SBLWH Electric dryer
General Electric DLB3600SBLAD Electric dryer
General Electric DLB3600SBLWH Electric dryer
General Electric DLB3600SBLWW Electric dryer
General Electric DLB3800SBLAD Electric dryer
General Electric DLB3800SBLWH Electric dryer
General Electric DLB3800SBLWW Electric dryer
General Electric DLB3900SAM Electric dryer
General Electric DLB3900SBM Electric dryer
General Electric DLB6850AAL Electric dryer
General Electric DLB6850BAL Electric dryer
General Electric DLB6850BBL Electric dryer
General Electric DLB6850BCL Electric dryer
General Electric DLB6850BDL Electric dryer
General Electric DLB6850BEL Electric dryer
General Electric DLB6850TA Electric dryer
General Electric DLB6850TDL Electric dryer
General Electric DLB6850TM Washer
Amana DLD10E COMMERCIAL MICROWAVES
Amana DLD10M COMMERCIAL MICROWAVES
Amana DLD10SE COMMERCIAL MICROWAVES
 DLE0332W Dryer
 DLE0442G Dryer
 DLE0442W Dryer
 DLE1310W Dryer
Amana DLE231RAW DRYER- ELE
 DLE2512W Dryer
 DLE2514W Dryer
 DLE2515S Dryer
 DLE2516W Dryer
 DLE2532W Dryer
Amana DLE330RAW DRYER- ELE
Amana DLE330RCW DRYER- ELE
 DLE3733D Dryer
 DLE3733S Dryer
 DLE3733U Dryer
 DLE3733W Dryer
 DLE3777W Dryer
 DLE5932S Dryer
 DLE5932W Dryer
 DLE5955G Dryer
 DLE5955W Dryer
 DLE5977B Dryer
 DLE5977S Dryer
 DLE5977SM Dryer
 DLE5977W Dryer
 DLE6942W Dryer
 DLE7177RM Dryer
 DLE7177WM Dryer
 DLE8377NM Dryer
 DLE8377WM Dryer
 DLE9577SM Dryer
 DLE9577WM Dryer
 DLEC733W Dryer
 DLEV833W Dryer
 DLEX0001TM Dryer
 DLEX2801L Dryer
 DLEX2801W Dryer
 DLEX3001P Dryer
 DLEX3001R Dryer
 DLEX3001W Dryer
 DLG0332W Dryer
 DLG0452G Dryer
 DLG0452W Dryer
 DLG1320W Dryer
Amana DLG231RAW DRYER- GAS
 DLG2522W Dryer
 DLG2524W Dryer
 DLG2525S Dryer
 DLG2526W Dryer
 DLG2532W Dryer
 DLG2602W Dryer
Amana DLG330RAW DRYER- GAS
Amana DLG330RCW DRYER- GAS
 DLG3744D Dryer
 DLG3744S Dryer
 DLG3744U Dryer
 DLG3744W Dryer
 DLG3788W Dryer
 DLG5932S Dryer
 DLG5932W Dryer
 DLG5966G Dryer
 DLG5966W Dryer
 DLG5988B Dryer
 DLG5988S Dryer
 DLG5988SM Dryer
 DLG5988W Dryer
 DLG6952W Dryer
 DLG7188RM Dryer
 DLG7188WM Dryer
 DLG8388NM Dryer
 DLG8388WM Dryer
 DLG9588SM Dryer
 DLG9588WM Dryer
 DLGX0002TM Dryer
 DLGX2802W Dryer
 DLGX3002P Dryer
 DLGX3002R Dryer
 DLGX3002W Dryer
General Electric DLL1550ABL Electric dryer
General Electric DLL1550BAL Gas dryer
General Electric DLL1550BBL Gas dryer
General Electric DLL1550BCL Gas dryer
General Electric DLL1550BDL Gas dryer
General Electric DLL1550BEL Gas dryer
General Electric DLL1550BFL Gas dryer
General Electric DLL1550BGL Gas dryer
General Electric DLL1550BHL Gas dryer
General Electric DLL1550RAL Gas dryer
General Electric DLL1550RBL Gas dryer
General Electric DLL1550RCL Gas dryer
General Electric DLL1550SBLAD Gas dryer
General Electric DLL1550SBLWH Gas dryer
General Electric DLL2450BGL Gas dryer
  #2 (permalink)
Old 03-03-2008, 09:39 AM
Junior Member
bcdc94 is on a distinguished road
Default hums but won't turn.
I had this same thing happen to me not long ago. First with the drum empty,(belt attached) door switch closed put the timer on a cycle and push start then try giving the drum a spin by hand (being careful of course) if it starts and then will spin you probably have a bad armature and need a new motor. If it still won't start with the push by hand check the voltage across the heating element, if it is 240 you have a bad motor. Hope that helps. BC
  #3 (permalink)
Old 06-29-2008, 02:36 PM
Junior Member
Mahnarch is on a distinguished road
Default
Dang it!
I'm having the same deal, only with a Whirlpool Estate.
I've checked all the wiring for burns and all the fuses are working.
Of course it'll be the hardest part to replace.
  #4 (permalink)
Old 06-30-2008, 12:33 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi Mahnarch,
Very likely the motor gone bad. For more accurate advise we need the complete model number of the dryer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #5 (permalink)
Old 07-01-2008, 10:15 AM
Junior Member
Default
Ah, thanks for the reply, Gene.
I can't find an older thread with my model, so I'll start a new thread.
Snagglepuss: "Exit. Stage left." *zooom*
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 28 12-10-2013 05:04 PM
Dryer hums, but won't start mvcampbell8 Dryer Repair 5 05-25-2010 07:28 AM
washer moter hums wtfchuck Washer Repair 1 08-29-2009 04:16 AM
Gas dryer motor hums but won't start nonqual Dryer Repair 5 12-27-2007 04:40 AM
Dryer hums but doesn't start bolinguist Dryer Repair 0 11-22-2007 04:06 PM
