Discuss
Installing drum bearing
 in
Dryer Repair
I am putting my drier back together, and have never worked on a stack unit like this. It came with
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Installing drum bearing
  #1 (permalink)
Old 03-02-2008, 06:40 PM
Junior Member
matthall9815 is on a distinguished road
Default Installing drum bearing
Model Number: 2sm2700wawww   Brand: GE   Age: 5 - 10 years
I am putting my drier back together, and have never worked on a stack unit like this. It came with a plastic bearing and bracket for the rear shaft. I assume I just fill the plastic bearing with the included lube, but what do I do with the single ball bearing included. Does it go in the hole in the rear of the plastic bearing? Any help appreciated.
Thanks,
Matt
Ads By Google
Related Models
Whirlpool 2VED21ZKFN00
Whirlpool 2VED21ZKFN01
Whirlpool 2VED21ZKFN02
Whirlpool 2VED21ZKFN03
Whirlpool 2VED21ZKFW00
Whirlpool 2VED21ZKFW01
Whirlpool 2VED21ZKFW02
Whirlpool 2VED21ZKFW03
Whirlpool 2VED27TKFN00
Whirlpool 2VED27TKFN01
Whirlpool 2VED27TKFW00
Whirlpool 2VED27TKFW01
Whirlpool 2VED27TKN00
Whirlpool 2VED27TKW00
Whirlpool 2VET20NKJN01
Whirlpool 2VET20NKJW00
Whirlpool 2VET20NKJW01
Whirlpool 2VET21DKJW00
Whirlpool 2VET21DKJW01
Whirlpool 2VET22NKJW00
Whirlpool 2VET22NKJW01
Whirlpool 2VET23DKJW00
Whirlpool 2VET23DKJW01
Whirlpool 2VET23DKJW02
Whirlpool 2VGD23DQFW00
Whirlpool 2VGD23DQFW02
Whirlpool 2VGD27DQFN00
Whirlpool 2VGD27DQFN01
Whirlpool 2VGD27DQFW00
Whirlpool 2VGD27DQFW01
Whirlpool 2VGD29DQFB00
Whirlpool 2VGD29DQFB01
Whirlpool 2VGD29DQFW00
Whirlpool 2VGD29DQFW01
Frigidaire 30-0127-23-03 Tap(v4) / Gas Range
Frigidaire 30-1049-00-01 Tap(v1) / Gas Range
Frigidaire 30-1049-00-02 Tap(v3) / Gas Range
Frigidaire 30-1049-00-03 Tap(v5) / Gas Range
Frigidaire 30-1049-00-04 Tap(v1) / Gas Range
Frigidaire 30-1049-00-05 Tap(v1) / Gas Range
Frigidaire 30-1049-00-06 Tap(v1) / Gas Range
Frigidaire 30-1049-00-07 Tap(v1) / Gas Range
Frigidaire 30-1049-00-08 Tap(v1) / Gas Range
Frigidaire 30-1049-00-09 Tap(v3) / Gas Range
Frigidaire 30-1049-00-10 Tap(v1) / Gas Range
Frigidaire 30-1049-00-11 Tap(v1) / Gas Range
Frigidaire 30-1049-23-01 Tap(v2) / Gas Range
Frigidaire 30-1049-23-02 Tap(v4) / Gas Range
Frigidaire 30-1049-23-03 Tap(v6) / Gas Range
Frigidaire 30-1049-23-04 Tap(v2) / Gas Range
Frigidaire 30-1049-23-05 Tap(v2) / Gas Range
Frigidaire 30-1049-23-06 Tap(v2) / Gas Range
Frigidaire 30-1049-23-07 Tap(v2) / Gas Range
Frigidaire 30-1049-23-08 Tap(v2) / Gas Range
Frigidaire 30-1049-23-09 Tap(v4) / Gas Range
Frigidaire 30-1049-23-10 Tap(v2) / Gas Range
Frigidaire 30-1049-23-11 Tap(v2) / Gas Range
Frigidaire 30-1149-00-01 Tap(v1) / Gas Range
Frigidaire 30-1149-00-02 Tap(v1) / Gas Range
Frigidaire 30-1149-00-03 Tap(v3) / Gas Range
Frigidaire 30-1149-00-04 Tap(v5) / Gas Range
Frigidaire 30-1149-00-05 Tap(v1) / Gas Range
Frigidaire 30-1149-00-06 Tap(v1) / Gas Range
Frigidaire 30-1149-00-07 Tap(v3) / Gas Range
Frigidaire 30-1149-00-08 Tap(v1) / Gas Range
Frigidaire 30-1149-00-10 Tap(v1) / Gas Range
Frigidaire 30-1149-00-11 Tap(v2) / Gas Range
Frigidaire 30-1149-00-12 Tap(v1) / Gas Range
Frigidaire 30-1149-23-01 Tap(v2) / Gas Range
Frigidaire 30-1149-23-02 Tap(v2) / Gas Range
Frigidaire 30-1149-23-03 Tap(v4) / Gas Range
Frigidaire 30-1149-23-04 Tap(v6) / Gas Range
Frigidaire 30-1149-23-05 Tap(v2) / Gas Range
Frigidaire 30-1149-23-06 Tap(v2) / Gas Range
Frigidaire 30-1149-23-07 Tap(v4) / Gas Range
Frigidaire 30-1149-23-08 Tap(v2) / Gas Range
Frigidaire 30-1149-23-10 Tap(v3) / Gas Range
Frigidaire 30-1149-23-11 Tap(v4) / Gas Range
Frigidaire 30-1149-23-12 Tap(v2) / Gas Range
Frigidaire 30-2022-00-11 Tap(v1) / Gas Range
Frigidaire 30-2022-23-11 Tap(v2) / Gas Range
Frigidaire 30-2022-45-11 Tap(v3) / Gas Range
Frigidaire 30-2022-57-11 Tap(v4) / Gas Range
Frigidaire 30-2022-66-11 Tap(v5) / Gas Range
Frigidaire 30-2118-00-01 Tap(v1) / Gas Range
Frigidaire 30-2118-00-02 Tap(v4) / Gas Range
Frigidaire 30-2118-00-03 Tap(v7) / Gas Range
Frigidaire 30-2118-00-04 Tap(v10) / Gas Range
Frigidaire 30-2118-23-01 Tap(v2) / Gas Range
Frigidaire 30-2118-23-02 Tap(v5) / Gas Range
Frigidaire 30-2118-23-03 Tap(v8) / Gas Range
Frigidaire 30-2118-23-04 Tap(v11) / Gas Range
Frigidaire 30-2118-66-01 Tap(v3) / Gas Range
Frigidaire 30-2118-66-02 Tap(v6) / Gas Range
Frigidaire 30-2118-66-03 Tap(v9) / Gas Range
Frigidaire 30-2118-66-04 Tap(v12) / Gas Range
Frigidaire 30-2119-00-01 Tap(v1) / Gas Range
Frigidaire 30-2119-00-02 Tap(v4) / Gas Range
Frigidaire 30-2119-23-01 Tap(v2) / Gas Range
Frigidaire 30-2119-23-02 Tap(v5) / Gas Range
Frigidaire 30-2119-66-01 Tap(v3) / Gas Range
Frigidaire 30-2119-66-02 Tap(v6) / Gas Range
Frigidaire 30-2132-00-01 Tap(v1) / Gas Range
Frigidaire 30-2132-00-02 Tap(v1) / Gas Range
Frigidaire 30-2132-00-03 Tap(v3) / Gas Range
Frigidaire 30-2132-00-04 Tap(v1) / Gas Range
Frigidaire 30-2132-23-01 Tap(v2) / Gas Range
Frigidaire 30-2132-23-02 Tap(v2) / Gas Range
Frigidaire 30-2132-23-03 Tap(v4) / Gas Range
Frigidaire 30-2132-23-04 Tap(v2) / Gas Range
Frigidaire 30-2138-00-01 Tap(v1) / Gas Range
Frigidaire 30-2138-00-02 Tap(v4) / Gas Range
Frigidaire 30-2138-00-03 Tap(v7) / Gas Range
Frigidaire 30-2138-00-04 Tap(v1) / Gas Range
Frigidaire 30-2138-00-05 Tap(v4) / Gas Range
Frigidaire 30-2138-00-06 Tap(v7) / Gas Range
Frigidaire 30-2138-23-01 Tap(v2) / Gas Range
Frigidaire 30-2138-23-02 Tap(v5) / Gas Range
Frigidaire 30-2138-23-03 Tap(v8) / Gas Range
Frigidaire 30-2138-23-04 Tap(v2) / Gas Range
  #2 (permalink)
Old 03-03-2008, 10:00 AM
Senior Expert
APP Volunteer
bentwrench1999 is on a distinguished road
Thumbs up Installing drum bearing
You Are Right On. It Goes Towards The Front Of The Dryer. Lube On The Ball Keeps It In Place. Good Luck....wrench
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Installing Hotpoint Rear Bearing Hopefulnow Dryer Repair 3 02-20-2010 07:10 PM
Installing new thrust bearing kit davho Washer Repair 2 02-05-2010 03:37 PM
drum bearing prn1955 Dryer Repair 1 08-12-2009 07:12 AM
Drum bearing kit bald2head Dryer Repair 2 12-17-2007 03:17 AM
installing the Assy, main bearing jdouglas14 Washer Repair 4 12-03-2007 05:33 PM
