Discuss
Dryer Heats A Little But Not Full Power!
 in
Dryer Repair
My dryer is not heating full power! It's drying only light clothes like shirts and jerseys but It won't dry
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Heats A Little But Not Full Power!
  #1 (permalink)
Old 11-18-2009, 09:12 AM
Junior Member
nrodulfo is on a distinguished road
Unhappy Dryer Heats A Little But Not Full Power!
Model Number: LER7648PT0   Brand: Whirlpool   Age: 1 - 5 years
My dryer is not heating full power! It's drying only light clothes like shirts and jerseys but It won't dry heavy clothes like jeans or jackets even when in high heat cycle. The heating element was replaced about three month ago and I checked to see if it was burned again but it look fine to me (last time it went bad you could see the damage). Anybody knows what could be wrong this time? I can't really afford to pay a repair guy to come fix it!! Any help would be much appreciated! Thanks!!
Ads By Google
Related Models
Whirlpool LER7648PT0 29" Electric Dryer
Whirlpool LER7648PT1 29" Electric Dryer
Whirlpool LER7848DQ0
Whirlpool LER7848DQ1
Whirlpool LER7848DZ0
Whirlpool LER7848DZ1
Whirlpool LER7858AN0
Whirlpool LER7858AN1
Whirlpool LER7858AN2
Whirlpool LER7858AW0
Whirlpool LER7858AW1
Whirlpool LER7858AW2
Whirlpool LER8620PG0 29"electric Dryer
Whirlpool LER8620PG1 29"electric Dryer
Whirlpool LER8620PW0 29"electric Dryer
Whirlpool LER8620PW1 29"electric Dryer
Whirlpool LER8648LG0
Whirlpool LER8648LG1 29"electric Dryer
Whirlpool LER8648LQ0
Whirlpool LER8648LW0
Whirlpool LER8648LW1 29"electric Dryer
Whirlpool LER8648PG0 29"electric Dryer
Whirlpool LER8648PG1 29"electric Dryer
Whirlpool LER8648PQ0 29" Electric Dryer
Whirlpool LER8648PQ1 29"electric Dryer
Whirlpool LER8648PW0 29"electric Dryer
Whirlpool LER8648PW1 29"electric Dryer
Whirlpool LER8857EQ0
Whirlpool LER8857EQ1
Whirlpool LER8857EQ2
Whirlpool LER8857EZ0
Whirlpool LER8857EZ1
Whirlpool LER8857EZ2
Whirlpool LER8858DQ0
Whirlpool LER8858DQ1
Whirlpool LER8858DZ0
Whirlpool LER8858DZ1
Whirlpool LER8858EQ0
Whirlpool LER8858EQ1
Whirlpool LER8858EQ2
Whirlpool LER8858EZ0
Whirlpool LER8858EZ1
Whirlpool LER8858EZ2
Amana LES10AW Washer - Top Loading
Amana LES19AW Dryer - Gas
Amana LES33AW Dryer - Gas
Amana LES34AW Washer - Top Loading
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Amana LET-480 Range - S/c S/i Ddraft Gas
Amana LET-480A Range - S/c S/i Ddraft Gas
Amana LET-480B Range - S/c S/i Ddraft Gas
Amana LET-480C Range - S/c S/i Ddraft Gas
Whirlpool LET5434AN0
Whirlpool LET5434AQ0
Whirlpool LET5434AW0
Whirlpool LET5436AN0
Whirlpool LET5436AW0
Whirlpool LET5624BN0
Whirlpool LET5624BN1
Whirlpool LET5624BN2
Whirlpool LET5624BQ0
Whirlpool LET5624BQ1
Whirlpool LET5624BQ2
Whirlpool LET5624BW0
Whirlpool LET5624BW1
Whirlpool LET5624BW2
Whirlpool LET5624DQ0
Whirlpool LET5624DQ1
Whirlpool LET6634AN0
Whirlpool LET6634AN1
Whirlpool LET6634AN2
Whirlpool LET6634AQ0
Whirlpool LET6634AQ1
Whirlpool LET6634AQ2
Whirlpool LET6634AW0
Whirlpool LET6634AW1
Whirlpool LET6634AW2
Whirlpool LET6634DQ0
Whirlpool LET6634DQ1
Whirlpool LET6634DZ0
Whirlpool LET6634DZ1
Whirlpool LET6638AN0
Whirlpool LET6638AN1
Whirlpool LET6638AN2
Whirlpool LET6638AQ2
Whirlpool LET6638AW0
Whirlpool LET6638AW1
Whirlpool LET6638AW2
Whirlpool LET6638DQ0
Whirlpool LET6638DQ1
Whirlpool LET6638DZ0
Whirlpool LET6638DZ1
Whirlpool LET7646AN0
Whirlpool LET7646AQ0
Whirlpool LET7646AQ1
Whirlpool LET7646AQ2
Whirlpool LET7646AW0
Whirlpool LET7646AZ0
Whirlpool LET7646AZ1
Whirlpool LET7646AZ2
Whirlpool LET7646DQ0
Whirlpool LET7646DQ1
Whirlpool LET7646DZ0
Whirlpool LET7646DZ1
Whirlpool LET7646EQ0
Whirlpool LET7646EQ1
Whirlpool LET7646EQ2
Whirlpool LET7646EZ0
Whirlpool LET7646EZ1
Whirlpool LET7646EZ2
Whirlpool LET7848AN0
Whirlpool LET7848AQ0
Whirlpool LET7848AQ1
Whirlpool LET7848AQ2
Whirlpool LET7848AW0
Whirlpool LET7848AZ0
Whirlpool LET7848AZ1
Whirlpool LET7848AZ2
Whirlpool LET7848DQ0
  #2 (permalink)
Old 11-18-2009, 10:38 AM
Junior Member
Greg01 is on a distinguished road
Default
You might check your circut breakers to see if one of the two has tripped. turn them both off then reset both. If onefeels mushy or loose you might have a bad breaker. Thats the first and easiest place to look.
  #3 (permalink)
Old 11-18-2009, 11:00 AM
Junior Member
Default
Thanks Greg01! But I just did that and both breakers are fine... They don't feel mushy or loose...
  #4 (permalink)
Old 11-18-2009, 01:07 PM
gabe_1981's Avatar
Senior Expert
APP Volunteer
gabe_1981 is on a distinguished road
Default
In my experence there is heat or no heat ... Never low heat ... I would look into airflow restiction ... best way to test venting from your dryer to the outside is to run a load with the dryer vent disconected.
  #5 (permalink)
Old 11-18-2009, 04:40 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If I got it right, we are talking about much longer time to dry a load and not about low heat. As gabe_1981 said, the most common cause in such situation is an obstructed vent and/or blocked air ducts inside the dryer as well as a broken blower wheel.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LER7648PT0 | AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #6 (permalink)
Old 11-22-2009, 09:30 AM
Junior Member
Default
Thanks for your responses guys! I did open the vents to check for lint and block and there was nothing. The blower wheel is also working fine. I got the dryer running with the vent disconnected to check the air flow and everything seems ok.
I was thinking... Since what I'm getting is low heat no matter in which cycle the dryer is, could it be that the cycle switch has gone bad? I don't know, is the only thing that comes to my mind because I do get heat, just very low and loads take forever to dry. Please let me know if that make sense so I can go ahead and buy that cycle switch.
Thanks for everything!!!
  #7 (permalink)
Old 11-24-2009, 07:51 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Locate the cycling thermostat (#8 on the diagram). It has two large and two small terminals. Remove one of two wires from a small terminal (either one) and insulate it. Run the dryer on high heat and post the result.
__________________
  #8 (permalink)
Old 12-01-2009, 10:23 PM
Junior Member
rickyyade is on a distinguished road
Default
Quote:
HI Gene I have done what you instructed above to myWhirlpool LER8857EQ1 dryer works fine now, is the temp selector or the cycling thermostat faulty.PLEASE HELP
  #9 (permalink)
Old 12-02-2009, 03:36 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
What is the original problem with the dryer?
__________________
  #10 (permalink)
Old 12-03-2009, 04:47 PM
Junior Member
Default
dryer taking long to dry a load .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Empty dryer will turn-Full won't DennisLu Dryer Repair 1 02-24-2010 08:26 AM
Has power, but nothing heats up HooverCO Oven Repair (including Ranges and Cooktops) 0 01-11-2010 07:20 PM
Whirpool Gold not freezing and fridge not at full power kinetikkurtis Refrigerator & Freezer Repair 3 10-05-2009 05:34 AM
dryer not running thru full cycle 30tredog Dryer Repair 3 09-28-2008 06:52 PM
