Discuss
Dryer won't keep running
 in
Dryer Repair
When we push the start button the dryer runs and fires only if you hold it on. It quits if
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer won't keep running
  #1 (permalink)
Old 11-18-2009, 09:00 AM
Junior Member
thomwes2 is on a distinguished road
Default Dryer won't keep running
Model Number: LGQ8858HQ0   Brand: Whirlpool   Age: 5 - 10 years
When we push the start button the dryer runs and fires only if you hold it on. It quits if you let the button up. I replaced the ignitor, flame sensor and coils. I have checked thermal fuse, and 2 thermostats. I think it has to do with the start relay but don't know how to remove or check to see if is is functioning.
Related Models
Whirlpool LGQ8858HQ0 GAS DRYER
Whirlpool LGQ8858HQ1 GAS DRYER
Whirlpool LGQ8858HZ0 GAS DRYER
Whirlpool LGQ8858HZ1 GAS DRYER
Whirlpool LGQ8858JQ0 GAS DRYER
Whirlpool LGQ8858JQ1 DRYER
Whirlpool LGQ8858JQ2 DRYER
Whirlpool LGQ8858JQ3 RESIDENTIAL DRYER
Whirlpool LGQ8858JT0 GAS DRYER
Whirlpool LGQ8858JT1 DRYER
Whirlpool LGQ8858JT2 DRYER
Whirlpool LGQ8858JT3 RESIDENTIAL DRYER
Whirlpool LGQ8858JZ0 GAS DRYER
Whirlpool LGQ8858JZ1 DRYER
Whirlpool LGQ8858JZ2 DRYER
Whirlpool LGQ9030PQ0 29"GAS DRYER
Whirlpool LGQ9030PQ1 29"GAS DRYER
Whirlpool LGQ9508KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9508KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9508LG0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW0 RESIDENTIAL DRYER
Whirlpool LGQ9508LW1 29"GAS DRYER
Whirlpool LGQ9508PG0 29"GAS DRYER
Whirlpool LGQ9508PG1 29"GAS DRYER
Whirlpool LGQ9508PW0 29"GAS DRYER
Whirlpool LGQ9508PW1 29"GAS DRYER
Whirlpool LGQ9557KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9557KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9557KT0 RESIDENTIAL DRYER
Whirlpool LGQ9557KT1 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ0 RESIDENTIAL DRYER
Whirlpool LGQ9558KQ1 RESIDENTIAL DRYER
Whirlpool LGQ9558KT0 RESIDENTIAL DRYER
Whirlpool LGQ9558KT1 RESIDENTIAL DRYER
Whirlpool LGQ9857LG0 RESIDENTIAL DRYER
Whirlpool LGQ9857LG1 29"GAS DRYER
Whirlpool LGQ9857LW0 RESIDENTIAL DRYER
Whirlpool LGQ9857LW1 29"GAS DRYER
Whirlpool LGQ9857PW0 29"GAS DRYER
Whirlpool LGQ9858LG0 RESIDENTIAL DRYER
Whirlpool LGQ9858LG1 29"GAS DRYER
Whirlpool LGQ9858LW0 RESIDENTIAL DRYER
Whirlpool LGQ9858LW1 29"GAS DRYER
Whirlpool LGQ9858PG0 29"GAS DRYER
Whirlpool LGQ9858PG1 29"GAS DRYER
Whirlpool LGQ9858PW0 29"GAS DRYER
Whirlpool LGQ9858PW1 29"GAS DRYER
Whirlpool LGR2614BW0 GAS DRYER
Whirlpool LGR2614BW1 GAS DRYER
Whirlpool LGR2614BW2 GAS DRYER
Whirlpool LGR2614DW0 GAS DRYER
Whirlpool LGR2614DW1 GAS DRYER
Whirlpool LGR2614EW0 GAS DRYER
Frigidaire LGR331DS0 Frigidaire/dryer
Admiral LGR3330ADB RANGE- S/C F/S GAS
Admiral LGR3330ADW RANGE- S/C F/S GAS
Admiral LGR3330ADZ RANGE- S/C F/S GAS
Whirlpool LGR3422AN0
Whirlpool LGR3422AW0 Residential Dryer
Whirlpool LGR3424AW0 Residential Dryer
Whirlpool LGR3622BN0 COMPACT GAS DRYER
Whirlpool LGR3622BW0 COMPACT GAS DRYER
Whirlpool LGR3622DQ1 COMPACT GAS DRYER
Whirlpool LGR3622DZ1 COMPACT GAS DRYER
Whirlpool LGR3624BN2 GAS DRYER
Whirlpool LGR3624BW0 GAS DRYER
Whirlpool LGR3624BW1 GAS DRYER
Whirlpool LGR3624BW2 GAS DRYER
Whirlpool LGR3624DQ1 GAS DRYER
Whirlpool LGR3624EQ0 GAS DRYER
Whirlpool LGR3624EQ1 GAS DRYER
Whirlpool LGR3624EQ2 GAS DRYER
Whirlpool LGR3624JQ0 GAS DRYER
Whirlpool LGR3624JQ1 RESIDENTIAL DRYER
Whirlpool LGR3624JQ2 29" GAS DRYER
Whirlpool LGR3624JQ3 29" GAS DRYER
Whirlpool LGR3624PQ0 29" GAS DRYER
Whirlpool LGR3624PQ1 29" GAS DRYER
Whirlpool LGR3634EW0 GAS DRYER
Whirlpool LGR3634EW1 GAS DRYER
Whirlpool LGR3634EW2 GAS DRYER
Whirlpool LGR3634EW3 GAS DRYER
Whirlpool LGR3634JW0 GAS DRYER
Whirlpool LGR3634JW1 RESIDENTIAL DRYER
Whirlpool LGR3634JW2 GAS DRYER
Admiral LGR3725ADC RANGE- S/C F/S GAS
Whirlpool LGR4434AN0 GAS DRYER
Whirlpool LGR4434AN1 GAS DRYER
Whirlpool LGR4434AQ0 Residential Dryer
Whirlpool LGR4434AQ1 GAS DRYER
Whirlpool LGR4434AW0 Residential Dryer
Whirlpool LGR4434AW1 GAS DRYER
Whirlpool LGR4436AW0 Residential Dryer
Whirlpool LGR4600PQ0 29" GAS DRYER
Whirlpool LGR4600PQ1 29" GAS DRYER
Whirlpool LGR4624BN0 GAS DRYER
Whirlpool LGR4624BN1 GAS DRYER
Whirlpool LGR4624BN2 GAS DRYER
Whirlpool LGR4624BQ0 GAS DRYER
Whirlpool LGR4624BQ1 GAS DRYER
Whirlpool LGR4624BQ2 GAS DRYER
Whirlpool LGR4624BW0 GAS DRYER
Whirlpool LGR4624BW1 GAS DRYER
Whirlpool LGR4624BW2 GAS DRYER
Whirlpool LGR4624DQ0 GAS DRYER
Whirlpool LGR4624DQ1 GAS DRYER
Whirlpool LGR4624DZ0 GAS DRYER
Whirlpool LGR4624DZ1 GAS DRYER
Whirlpool LGR4634BQ0 GAS DRYER
Whirlpool LGR4634BQ1 GAS DRYER
Whirlpool LGR4634BQ2 GAS DRYER
Whirlpool LGR4634DQ0 DRYERS
Whirlpool LGR4634DQ1 GAS DRYER
Whirlpool LGR4634DQO GAS DRYER
Whirlpool LGR4634DZ0 DRYERS
Whirlpool LGR4634DZO GAS DRYER
Whirlpool LGR4634EQ0 GAS DRYER
Whirlpool LGR4634EQ1 GAS DRYER
Whirlpool LGR4634EQ2 GAS DRYER
Whirlpool LGR4634EQ3 GAS DRYER
  #2 (permalink)
Old 11-18-2009, 03:45 PM
Junior Member
Red face solution to dryer won't stay on
I finally got the start relay switch out. There is a bar you lift up and then twist it and it comes out. I pulled the switch apart and found that the coil wire was broken. I got a new switch relay and installed and it works like a champ
  #3 (permalink)
Old 11-18-2009, 04:56 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Yeah, it is not intuitively obvious. Thanks for the update, because this is a common problem.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't keep running poetkinsle Dryer Repair 0 11-21-2009 01:09 PM
Dryer running hot Rayb32 Dryer Repair 5 07-12-2009 07:58 PM
Dryer not running pwrply2 Dryer Repair 1 04-17-2008 06:09 AM
Dryer won't keep running mnovara Dryer Repair 2 02-21-2008 05:50 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
