MRCOBRA93
#1 Posted : Tuesday, November 17, 2009 7:19:51 AM(UTC)
MRCOBRA93
i just replaced the heating element and still no heat.i was looking at thanging the saftey thermostat do you think this could be the problem??
#2 Posted : Wednesday, November 18, 2009 4:30:35 AM(UTC)
Replacement parts for GE DVL223EB4WW | AppliancePartsPros.com
I would check the thermal limiter, Item 1236 in Section 1, then the safety thermostat 1236 in Section 1.
Both should be 0 ohms. If the fuse is blown I would replace both.
If the fuse is gone.
Clean and check the blower wheel and the vent system.
Make sure the lint filter is not coated with fabric softener residue.
Check that the drum seals, 1220, 1221 & 1271 in Section 3 are OK
