| » Dangerous gas ignitor |
Model Number: 110.97283110 Brand: Kenmore Age: More than 10 years
Intermintent problem with gas solenoid ignitor starting prior to start button being pushed. Setting of timer will activate the gas valve ignitor (ONLY OCCASIONALLY). New motor, rollers and belt installed a week ago.
Related Models |
Very likely there is a shorted wire which goes from the motor centrifugal switch to the gas valve.
__________________
Professional appliance repair in Orange County, California. |
Thanks for the response Gene. Based on the wiring diagram it appears that contact 1M and 2M on the motor switch completes the circuit to the gas valve. Since there is no visible short circuit on the connections could the switch on this new replacement motor be sticking periodically??
Five or even three years ago I will say "NO". Today I'm saying "Who knows?".
Anyway, check the wire first. Gene.
__________________
You were correct Gene. An inspection of the wires on the motor centrifugal switch revealed one lone copper strand from the 6M wire out of its crimp connector and in close proximity to the 2M wire.
Probable intermitent contact between the two causing the occasional short circuit to the gas valve when timer contacts are closed. Removed the offending connector and replaced it with an insulated one, making sure there were no strands exposed. So far so good. Thanks for your assistance. |
You are welcome. I'm glad you were able to fix it.
__________________
| Display Modes | |
| How dangerous is it... | StefGal | Microwave Repair | 0 | 08-27-2009 11:18 AM |
| ignitor | jstival1 | Oven Repair (including Ranges and Cooktops) | 1 | 07-13-2009 03:13 PM |
| looking for ignitor p/n | willhess | Oven Repair (including Ranges and Cooktops) | 9 | 06-24-2009 05:29 AM |
| Dishwasher Heater Stays On - very dangerous | StewartLL | Dishwasher Repair | 0 | 02-26-2009 04:48 PM |
| Gas ignitor | Loretta | Oven Repair (including Ranges and Cooktops) | 3 | 03-30-2008 06:39 PM |
