Discuss
Gas Dryer no flame
 in
Dryer Repair
I hear one click as I start the dryer and the tumbling begins. There seems to be no heat. When
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas Dryer no flame
  #1 (permalink)
Old 03-01-2008, 11:58 AM
Jimbeau Jimbeau is offline
Junior Member
Jimbeau is on a distinguished road
Cool Gas Dryer no flame
Model Number: mdg308daww   Brand: Maytag   Age: 1 - 5 years
I hear one click as I start the dryer and the tumbling begins. There seems to be no heat. When I turn off I hear one click again. I changed the ignitor and the solinoid coils. The original ignitor read 46 ohms and the new one reads 18 ohms. The new ignitor seems a bit different because the ceramic part is a bit larger but the metal part seems identical and it fits in the place fine so I believe it is the correct part for my unit. I checked continuity on the thermal fuse, radiant sensor and the thermostat that are all located in the same area around the gas tubing assembly. All of these parts read 0 ohms, which I believe is fine. I removed the exhaust tubing to see if that was the problem and it still would not heat up. I have not looked inside to see if there is glowing or anything while the machine tumbles. I do not believe there is a view hole. Please help!!!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-09-2008, 06:58 PM
Junior Member
Default
Well I had to call in the professionals. After replacing the ignitor and the coils. He took look at skematic which apparently is a sheet of paper in every appliance somewhere. it was in the top in this case and with that he determined the problem was in the centrifical switch on the motor. He didnt think that coulld be the problem since it rarely goes. Upon removing the drum to get to the motor it was immediately obvious that the wire was loose. Problem solved. $65 and no part needed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas oven, flame goes out after being lit rotten Oven Repair (including Ranges and Cooktops) 4 01-25-2008 06:11 PM
flame on than off milhouse Dryer Repair 0 12-30-2007 05:54 PM
Whirlpool gas dryer will not maintain flame smsgtweber Dryer Repair 1 12-09-2007 06:44 AM
Gas dryer starts fine gas flame runs 10-15 min and then quits Krsolo Dryer Repair 3 10-23-2007 09:44 AM
Igniter glows but no flame. zab Dryer Repair 1 08-06-2007 07:55 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
