Discuss
Dryer Won't Stay Running
 in
Dryer Repair
DRY WILL START RUN 2-3 SECOND THAN STOP. PUSH START BUTTON FEELS FUNNY AFTER SHUT OFF. THERE SEEMS TO BE
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer Won't Stay Running
  #1 (permalink)
Old 11-15-2009, 08:19 PM
Junior Member
MONA SMITH is on a distinguished road
Default Dryer Won't Stay Running
Model Number: LER8648PW0   Brand: Whirlpool   Age: 1 - 5 years
DRY WILL START RUN 2-3 SECOND THAN STOP. PUSH START BUTTON FEELS FUNNY AFTER SHUT OFF. THERE SEEMS TO BE A ELECTRICAL BURNING SMELL AT THIS TIME. JUMPED THE WHITE FUSE AT THE EXHAUST NO CHANGE, HEATED SENSOR BY EXHAUST IT CLICKED, NO CHANGE, PUSH START SWITCH HAS OMHS. TIMER TICKS BUT DOES NOT BUZZ.
DRY WAS DIRTY IN SIDE AND WE CLEANED IT OUT BUT NO CHANGE.
Related Models
Whirlpool LER8648PW0 29"ELECTRIC DRYER
Whirlpool LER8648PW1 29"ELECTRIC DRYER
Whirlpool LER8857EQ0 ELECTRIC DRYER
Whirlpool LER8857EQ1 DRYERS
Whirlpool LER8857EQ2 ELECTRIC DRYER
Whirlpool LER8857EZ0 ELECTRIC DRYER
Whirlpool LER8857EZ1 DRYERS
Whirlpool LER8857EZ2 ELECTRIC DRYER
Whirlpool LER8858DQ0 ELECTRIC DRYER
Whirlpool LER8858DQ1 ELECTRIC DRYER
Whirlpool LER8858DZ0 ELECTRIC DRYER
Whirlpool LER8858DZ1 ELECTRIC DRYER
Whirlpool LER8858EQ0 ELECTRIC DRYER
Whirlpool LER8858EQ1 DRYERS
Whirlpool LER8858EQ2 ELECTRIC DRYER
Whirlpool LER8858EZ0 ELECTRIC DRYER
Whirlpool LER8858EZ1 DRYERS
Whirlpool LER8858EZ2 ELECTRIC DRYER
Whirlpool LER8875EQ1 ELECTRIC DRYER
Amana LES10AW WASHER-TOP LOADING
Amana LES19AW DRYER- GAS
Amana LES33AW DRYER- GAS
Amana LES34AW WASHER-TOP LOADING
Frigidaire LES389FEA Frigidaire/electric Range
Frigidaire LESR26EFE0 Frigidaire/refrigerator
Frigidaire LESR26EFE3 REFRIGERATOR
Frigidaire LESR26EFE4 REFRIGERATOR
Frigidaire LESR26EFE5 REFRIGERATOR
Frigidaire LESR26EFE6 REFRIGERATOR
Frigidaire LESR26EFE7 REFRIGERATOR
Whirlpool LET5434AQ0 Residential Dryer
Whirlpool LET5434AW0 Residential Dryer
Whirlpool LET5436AW0 Residential Dryer
Whirlpool LET5624BN0 ELECTRIC DRYER
Whirlpool LET5624BN1 ELECTRIC DRYER
Whirlpool LET5624BN2 ELECTRIC DRYER
Whirlpool LET5624BQ0 ELECTRIC DRYER
Whirlpool LET5624BQ1 ELECTRIC DRYER
Whirlpool LET5624BQ2 ELECTRIC DRYER
Whirlpool LET5624BW0 ELECTRIC DRYER
Whirlpool LET5624BW1 ELECTRIC DRYER
Whirlpool LET5624BW2 ELECTRIC DRYER
Whirlpool LET5624DQ0 ELECTRIC DRYER
Whirlpool LET5624DQ1 DRYER
Whirlpool LET6634AN1 ELECTRIC DRYER
Whirlpool LET6634AN2 ELECTRIC DRYER
Whirlpool LET6634AQ0 ELECTRIC DRYER
Whirlpool LET6634AQ1 ELECTRIC DRYER
Whirlpool LET6634AQ2 ELECTRIC DRYER
Whirlpool LET6634AW0 Residential Dryer
Whirlpool LET6634AW1 ELECTRIC DRYER
Whirlpool LET6634AW2 ELECTRIC DRYER
Whirlpool LET6634DQ0 ELECTRIC DRYER
Whirlpool LET6634DQ1 ELECTRIC DRYER
Whirlpool LET6634DZ0 ELECTRIC DRYER
Whirlpool LET6634DZ1 ELECTRIC DRYER
Whirlpool LET6638AN1 DRYER
Whirlpool LET6638AN2 ELECTRIC DRYER
Whirlpool LET6638AQ2 ELECTRIC DRYER
Whirlpool LET6638AW0 Residential Dryer
Whirlpool LET6638AW1 DRYER
Whirlpool LET6638AW2 ELECTRIC DRYER
Whirlpool LET6638DQ0 ELECTRIC DRYER
Whirlpool LET6638DQ1 ELECTRIC DRYER
Whirlpool LET6638DZ0 ELECTRIC DRYER
Whirlpool LET6638DZ1 ELECTRIC DRYER
Whirlpool LET7646AQ0 Residential Dryer
Whirlpool LET7646AQ1 ELECTRIC DRYER
Whirlpool LET7646AQ2 ELECTRIC DRYER
Whirlpool LET7646AW0 Residential Dryer
Whirlpool LET7646AZ1 ELECTRIC DRYER
Whirlpool LET7646AZ2 ELECTRIC DRYER
Whirlpool LET7646DQ0 ELECTRIC DRYER
Whirlpool LET7646DQ1 ELECTRIC DRYER
Whirlpool LET7646DZ0 ELECTRIC DRYER
Whirlpool LET7646DZ1 ELECTRIC DRYER
Whirlpool LET7646EQ0 ELECTRIC DRYER
Whirlpool LET7646EQ1 DRYERS
Whirlpool LET7646EQ2 ELECTRIC DRYER
Whirlpool LET7646EZ0 ELECTRIC DRYER
Whirlpool LET7646EZ1 DRYERS
Whirlpool LET7646EZ2 ELECTRIC DRYER
Whirlpool LET7848AQ0 Residential Dryer
Whirlpool LET7848AQ1 ELECTRIC DRYER
Whirlpool LET7848AQ2 ELECTRIC DRYER
Whirlpool LET7848AW0 Residential Dryer
Whirlpool LET7848AZ1 ELECTRIC DRYER
Whirlpool LET7848AZ2 ELECTRIC DRYER
Whirlpool LET7848DQ0 ELECTRIC DRYER
Whirlpool LET7848DQ1 ELECTRIC DRYER
Whirlpool LET7848DZ0 ELECTRIC DRYER
Whirlpool LET7848DZ1 ELECTRIC DRYER
Whirlpool LET8858AN1 ELECTRIC DRYER
Whirlpool LET8858AN2 ELECTRIC DRYER
Whirlpool LET8858AQ0 ELECTRIC DRYER
Whirlpool LET8858AQ1 ELECTRIC DRYER
Whirlpool LET8858AQ2 ELECTRIC DRYER
Whirlpool LET8858AW0 Residential Dryer
Whirlpool LET8858AW1 ELECTRIC DRYER
Whirlpool LET8858AW2 ELECTRIC DRYER
Whirlpool LET8858AZ0 ELECTRIC DRYER
Whirlpool LET8858AZ1 ELECTRIC DRYER
Whirlpool LET8858AZ2 ELECTRIC DRYER
Whirlpool LET8858DQ0 ELECTRIC DRYER
Whirlpool LET8858DQ1 ELECTRIC DRYER
Whirlpool LET8858DZ0 ELECTRIC DRYER
Whirlpool LET8858DZ1 ELECTRIC DRYER
Amana LEU108 RANGE- S/C S/I DDRAFT GAS
Whirlpool LEV4434AW0 Residential Dryer
Whirlpool LEV4436AW0 Residential Dryer
Whirlpool LEV4624BG0 ELECTRIC DRYER
Whirlpool LEV4624BN0 ELECTRIC DRYER
Whirlpool LEV4624BW0 ELECTRIC DRYER
Whirlpool LEV4634JQ0 ELECTRIC DRYER
Whirlpool LEV4634JQ1 RESIDENTIAL DRYER
Whirlpool LEV4634JQ2 29" ELECTRIC DRYER
Whirlpool LEV4634JT0 ELECTRIC DRYER
Whirlpool LEV4634JT1 RESIDENTIAL DRYER
Whirlpool LEV4634PQ0 29" ELECTRIC DRYER
Whirlpool LEV4634PQ1 29" ELECTRIC DRYER
  #2 (permalink)
Old 11-16-2009, 05:28 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Here is your wiring diagram
http://www.servicematters.com/docs/w...%203979703.pdf
Your problem should not be related to the heating element etc.
I have no idea on this symptom
This could be the motor overheating. If the motor is overheating, it will trip it's internal thermal protect and you will not be able to restart it right away. The motor has to cool down for the protect to reset.
Try turning the drum by hand, should turn fairly easily. This is just in case the motor is overloaded but it is probably OK.
It sounds like the centrifugal switch for the motor's start winding is not opening. Then the start winding stays energized and the motor overheats.
This could be that the mechanism on the motor which activates the switch is clogged solid with dust.
If this was gone it would kill power to the unit so it would not even start.
Would not effect starting
Should have 0 ohms when pushed. Again it would not start at all if this was toast
Not sure what this means
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dryer won't stay running. nwpop05 Dryer Repair 1 01-14-2010 03:35 AM
dryer won't stay running buzlong Dryer Repair 0 11-14-2009 03:57 PM
Dryer won't stay running Fixitchick Dryer Repair 3 09-24-2009 09:22 PM
G.E. gas dryer will not stay running skonny Dryer Repair 0 09-17-2009 07:12 AM
dryer won't stay running teetwofalcon Dryer Repair 1 08-08-2009 09:13 AM
