benjiestep
#1 Posted : Sunday, November 15, 2009 1:31:50 PM(UTC)
benjiestep
The dryer gets hot, but it takes two cycles to get each load dry. I don't know if it is the heating element or not.
magician59
#2 Posted : Sunday, November 15, 2009 1:56:56 PM(UTC)
magician59
Longer drying times are an indication of clogged or restricted ventilation. If allowed to continue long, the high limit thermostat or the thermal fuse can open; then you'll have no heat.
Roper Dryer RES7745PQ0 (Dryer Repair)
by ARC575 4/19/2020 3:58:45 PM(UTC)
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
roper dryer (Dryer Repair)
by smoke-71 3/3/2015 3:56:21 AM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
