| » Electric He3 dryer |
A Model Number may help others help you.
Flip your breaker off/on slowly a couple times. Sometimes you can loose half the line without tripping the breaker and the heating element requires the full 240 volts. Better yet measure it at the plug with a meter, L1 to L2 should be 240 volts. Next would be to unplug the unit and check that the wires at the terminal block are OK Next check for a blown heater. Then you have the heater thermal fuse, if it has one and the thermostats
__________________
- Last edited by denman : 11-15-2009 at 02:43 AM. |
| Display Modes | |
| Burned Dryer Plug - Whirlpool Electric Dryer | EastCobbSnob | Dryer Repair | 4 | 11-17-2009 06:45 PM |
| ELECTRIC Dryer | Max Harlan | Dryer Repair | 6 | 04-26-2009 05:51 AM |
| Electric dryer will not run | GA60 | Dryer Repair | 0 | 02-08-2009 06:10 AM |
| Electric dryer gets too hot | cojo1957 | Dryer Repair | 2 | 10-28-2008 04:50 AM |
| Gas dryer to electric dryer convertion. | Fhabeeow | Dryer Repair | 1 | 01-08-2008 07:49 PM |
