Discuss
Burned Dryer Plug - Whirlpool Electric Dryer
 in
Dryer Repair
I came home 2 nights ago to smell something burning from my laundry room. When I got there, smoke was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Burned Dryer Plug - Whirlpool Electric Dryer
  #1 (permalink)
Old 11-13-2009, 04:55 PM
Junior Member
EastCobbSnob is on a distinguished road
Default Burned Dryer Plug - Whirlpool Electric Dryer
Model Number: LER5636EQ3   Brand: Whirlpool   Age: 5 - 10 years
I came home 2 nights ago to smell something burning from my laundry room. When I got there, smoke was coming from behind the dryer. I disconnected the fuse from the electrical panel and unplugged the dryer. (See attached photo).
First, I assume the problem is on the dryer side?
If so, I'm not sure what might have caused it (heating element?). I pulled the heating element out and took a picture.
The dryer is 10 years old.
Any help would be appreciated.
Steven
Ads By Google
Related Models
Whirlpool LER5636EQ3
Whirlpool LER5636EZ0
Whirlpool LER5636EZ1
Whirlpool LER5636EZ2
Whirlpool LER5636EZ3
Whirlpool LER5636JQ0
Whirlpool LER5636JT0
Whirlpool LER5636KQ0
Whirlpool LER5636KQ1
Whirlpool LER5636KT0
Whirlpool LER5636KT1
Whirlpool LER5636LG0
Whirlpool LER5636LQ0
Whirlpool LER5636LQ1 29"electric Dryer
Whirlpool LER5636LT0
Whirlpool LER5636LT1 29"electric Dryer
Whirlpool LER5636LW0
Whirlpool LER5636PQ0 29"electric Dryer
Whirlpool LER5636PQ1 29"electric Dryer
Whirlpool LER5636PT0 29"electric Dryer
Whirlpool LER5636PT1 29"electric Dryer
Whirlpool LER5638AN0
Whirlpool LER5638AN1
Whirlpool LER5638AN2
Whirlpool LER5638AN3
Whirlpool LER5638AW0
Whirlpool LER5638AW1
Whirlpool LER5638AW2
Whirlpool LER5638AW3
Whirlpool LER5644AN0
Whirlpool LER5644AN1
Whirlpool LER5644AN2
Whirlpool LER5644AW0
Whirlpool LER5644AW1
Whirlpool LER5644AW2
Whirlpool LER5644EQ0
Whirlpool LER5644EQ1
Whirlpool LER5644EQ2
Whirlpool LER5644EZ0
Whirlpool LER5644EZ1
Whirlpool LER5644EZ2
Whirlpool LER5644JQ0
Whirlpool LER5644JQ1
Whirlpool LER5644JQ2
Whirlpool LER5644JQ3 29"electric Dryer
Whirlpool LER5644JT0
Whirlpool LER5644JT1
Whirlpool LER5644JT2
Whirlpool LER5644JT3 29"electric Dryer
Whirlpool LER5644PQ0 29"electric Dryer
Whirlpool LER5644PQ1 29"electric Dryer
Whirlpool LER5700KQ0
Whirlpool LER5700KQ1
Whirlpool LER5700KT0
Whirlpool LER5700KT1
Whirlpool LER5848EQ0
Whirlpool LER5848EQ1
Whirlpool LER5848EQ2
Whirlpool LER5848EQ3
Whirlpool LER5848EQ4
Whirlpool LER5848EQ5
Whirlpool LER6611LQ0
Whirlpool LER6611LQ1 29"electric Dryer
Whirlpool LER6611PQ0 29" Electric Dryer
Whirlpool LER6620PQ0 29"electric Dryer
Whirlpool LER6620PQ1 29"electric Dryer
Whirlpool LER6620PT0 29"electric Dryer
Whirlpool LER6620PT1 29"electric Dryer
Whirlpool LER6621PQ0 29" Electric Dryer
Whirlpool LER6634BN0
Whirlpool LER6634BN1
Whirlpool LER6634BN2
Whirlpool LER6634BQ0
Whirlpool LER6634BQ1
Whirlpool LER6634BQ2
Whirlpool LER6634BW0
Whirlpool LER6634BW1
Whirlpool LER6634BW2
Whirlpool LER6634DQ0
Whirlpool LER6634DQ1
Whirlpool LER6634DW0
Whirlpool LER6634DW1
Whirlpool LER6634DZ0
Whirlpool LER6634DZ1
Whirlpool LER6636PW0 29" Electric Dryer
Whirlpool LER6636PW1 29" Electric Dryer
Whirlpool LER6638DQ0
Whirlpool LER6638DQ1
Whirlpool LER6638DW0
Whirlpool LER6638DW1
Whirlpool LER6638DZ0
Whirlpool LER6638DZ1
Whirlpool LER6644DQ0
Whirlpool LER6644DQ1
Whirlpool LER6644DZ0
Whirlpool LER6644DZ1
Whirlpool LER6646BN0
Whirlpool LER6646BN1
Whirlpool LER6646BN2
Whirlpool LER6646BW0
Whirlpool LER6646BW1
Whirlpool LER6646BW2
Whirlpool LER6646DN1
Whirlpool LER6646DW1
Whirlpool LER6646PW0 29" Electric Dryer
Whirlpool LER6646PW1 29" Electric Dryer
Whirlpool LER6848AN0
Whirlpool LER6848AN1
Whirlpool LER6848AN2
Whirlpool LER6848AQ2
Whirlpool LER6848AW0
Whirlpool LER6848AW1
Whirlpool LER6848AW2
Whirlpool LER6848AZ2
Whirlpool LER7620KQ0
Whirlpool LER7620KQ1
Whirlpool LER7620KT0
Whirlpool LER7620KT1
Whirlpool LER7620LG0
Whirlpool LER7620LG1 29"electric Dryer
  #2 (permalink)
Old 11-14-2009, 03:04 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Replacement parts for WHIRLPOOL LER5636EQ3 | AppliancePartsPros.com
Here is a wiring diagram
http://www.servicematters.com/docs/w...%203406688.pdf
Check your heating element with meter.
The element should be around 10 ohms. Then check from each side to the case both should be Infinite ohms (open)
You will of coarse have to replace the line cord.
When you do, check that the wires at the units terminal strip are all OK.
Also check that the ground strap from the Neutral to the machine's frame is connected and looks OK.
You will also have to replace the receptacle in the wall.
Note, that is very important that the house wiring is cut back till you get to nice clean copper wiring with no overheating of the wire insulation.
I would also replace the circuit breaker in the panel just to be sure that it is OK as it may not have tripped when it should have. Also check the wiring in the panel.
After the wall receptacle is rewired check it with a meter to ensure you are getting the correct power.
L1 to L2 should be 240 volts.
A possible cause of this is a bad/poor connection of the plug to receptacle or of the wire to the plug's prong inside the line cord. This would create a resistance at this point. As current flows through this connection it creates heat which makes the connection worse, which creates more heat and so on and so on till the connection fails. Once the plastic gets not enough to turn black it turns to carbon and now you have a very serious condition.
I must say you were very lucky as it could have cost you your house.
__________________
  #3 (permalink)
Old 11-15-2009, 12:38 PM
Junior Member
Default my responses.
Looks like I will need help with this one. I attached photos of some measurements I took with my multimeter. I'm not getting anything on the heating element thermostat (I tried every combination of connections), but I'm getting a reading from the other one.
I replaced the cord. Everything around there looks good.
I stripped the wires back to some clean copper and replaced the receptacle.
will work on this one next weekend.
I got these readings from my multimeter.
This "possible cause" probably is correct. the receptacle wasn't properly attached to the wall, so part of it would hang loosely from the wall. I corrected that with the new receptacle.
  #4 (permalink)
Old 11-16-2009, 04:53 AM
Senior Expert
APP Volunteer
Default
On your meter readings. Note: I am a tad rusty as I have not used an analogue meter in about 30 years.
First picture.
Remove the red wires. Then check across heater Red to orange. Should be around 10 ohms. If I remember correctly a reading of 1 will be 1,000 ohms so it will probably look like a dead short just because of your meter scale/sensitivity.
But that is OK.
Next measure from the red to the case, should be infinite ohms (open), meter dial stays to the left.
Then do the same from the orange to the frame, also should be an open.
This is testing to see if you have a grounded element.
Then check across the thermostat, should be 0 ohms. Meter all the way right.
If the above are OK reconnect the wires and you should be good to go.
Third picture:
This thermostat has an internal heater that is why it has 4 wires.
Contacts - red to red Should be 0 ohms
Internal heater - violet to violet Should be about 7,000 ohms. 7 on your meter.
One thing I notice is the way you are measuring. It is always a good idea to remove at least one wire from any device you are measuring for resistance. This prevents you from reading an alternate/parallel circuit path.
Hope the above helps.
__________________
  #5 (permalink)
Old 11-17-2009, 06:45 PM
Junior Member
Default
Went through all the steps. everything checked out. Plugged everything back in and it works!
Can't thank den man enough for all your help.
Steven
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Electric Dryer jcarroll1 Dryer Repair 1 09-17-2009 05:14 AM
Convert Kitchen Aid Dryer from 3 Prong Plug to 4 Prong Plug edd225 Dryer Repair 2 04-16-2009 06:59 PM
whirlpool electric dryer KRO Dryer Repair 1 04-26-2008 04:27 PM
Whirlpool Electric Dryer kwillson Dryer Repair 1 03-28-2008 03:30 PM
Whirlpool Electric Dryer mopsgt Dryer Repair 5 03-12-2008 03:59 PM
