wbuc
#1 Posted : Thursday, February 28, 2008 5:49:05 PM(UTC)
wbuc
My Dryer stopped heating up so I check for continuity and found the Thermal Cut off was defective. I replaced it and the high limit as they came in a set (part 47 and 48). The dryer worked great for 3 months and then the same problem occurred again. Bad Thermal Cut Off.
What could cause this part to keep going bad?
Wbuc
#2 Posted : Friday, February 29, 2008 12:04:58 PM(UTC)
One of most common problem caused a dryer to overheat is restricted exhaust line.
Also I would recommend to check the blower wheel and the air duct inside the dryer.
Here are the break down diagrams for the Whirlpool dryer Model GEQ8858JQ1
