Discuss
HELP!!! Dryer has no heat
 in
Dryer Repair
Dryer will not heat - Whirlpool model LGR6848AZ2. Yesterday, the dryer wouldn't tumble. I changed the belt & it fixed
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » HELP!!! Dryer has no heat
  #1 (permalink)
Old 11-12-2009, 07:44 AM
Junior Member
quinn9829 is on a distinguished road
Default HELP!!! Dryer has no heat
Model Number: LGR6848AZ2   Brand: Whirlpool   Age: 5 - 10 years
Dryer will not heat - Whirlpool model LGR6848AZ2. Yesterday, the dryer wouldn't tumble. I changed the belt & it fixed the problem...temporarily. I did 4 loads of laundry just fine. Now the dryer tumbles but has no heat. I tested the outlet w/ multimeter, it's fine. What did I break? Any help would be greatly appreciated! Thanks!
Related Models
Whirlpool LGR6848AZ2 GAS DRYER
Whirlpool LGR7620KQ0 RESIDENTIAL DRYER
Whirlpool LGR7620KQ1 RESIDENTIAL DRYER
Whirlpool LGR7620KT0 RESIDENTIAL DRYER
Whirlpool LGR7620KT1 RESIDENTIAL DRYER
Whirlpool LGR7620LG0 RESIDENTIAL DRYER
Whirlpool LGR7620LG1 29"GAS DRYER
Whirlpool LGR7620LQ0 RESIDENTIAL DRYER
Whirlpool LGR7620LW0 RESIDENTIAL DRYER
Whirlpool LGR7620LW1 29"GAS DRYER
Whirlpool LGR7645JQ0 GAS DRYER
Whirlpool LGR7645JQ1 GAS DRYER
Whirlpool LGR7645JQ2 DRYER
Whirlpool LGR7646AN0 GAS DRYER
Whirlpool LGR7646AN1 GAS DRYER
Whirlpool LGR7646AN2 GAS DRYER
Whirlpool LGR7646AQ0 GAS DRYER
Whirlpool LGR7646AQ1 GAS DRYER
Whirlpool LGR7646AQ2 GAS DRYER
Whirlpool LGR7646AW0 Residential Dryer
Whirlpool LGR7646AW1 GAS DRYER
Whirlpool LGR7646AW2 GAS DRYER
Whirlpool LGR7646AZ0 GAS DRYER
Whirlpool LGR7646AZ1 GAS DRYER
Whirlpool LGR7646AZ2 GAS DRYER
Whirlpool LGR7646DQ0 GAS DRYER
Whirlpool LGR7646DQ1 GAS DRYER
Whirlpool LGR7646DW0 GAS DRYER
Whirlpool LGR7646DW1 GAS DRYER
Whirlpool LGR7646DZ0 GAS DRYER
Whirlpool LGR7646DZ1 GAS DRYER
Whirlpool LGR7646EQ0 DRYER
Whirlpool LGR7646EQ1 DRYERS
Whirlpool LGR7646EQ2 GAS DRYER
Whirlpool LGR7646EQ3 GAS DRYER
Whirlpool LGR7646EZ0 DRYER
Whirlpool LGR7646EZ1 DRYERS
Whirlpool LGR7646EZ2 GAS DRYER
Whirlpool LGR7646EZ3 GAS DRYER
Whirlpool LGR7646JQ0 GAS DRYER
Whirlpool LGR7646JQ1 RESIDENTIAL DRYER
Whirlpool LGR7646JT0 GAS DRYER
Whirlpool LGR7646JT1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ0 RESIDENTIAL DRYER
Whirlpool LGR7648KQ1 RESIDENTIAL DRYER
Whirlpool LGR7648KQ2 29"GAS DRYER
Whirlpool LGR7648KT0 RESIDENTIAL DRYER
Whirlpool LGR7648KT1 RESIDENTIAL DRYER
Whirlpool LGR7648KT2 29"GAS DRYER
Whirlpool LGR7648PQ0 29" GAS DRYER
Whirlpool LGR7648PQ1 29" GAS DRYER
Whirlpool LGR7648PT0 29" GAS DRYER
Whirlpool LGR7648PT1 29" GAS DRYER
Whirlpool LGR7848DQ0 GAS DRYER
Whirlpool LGR7848DQ1 GAS DRYER
Whirlpool LGR7848DZ0 GAS DRYER
Whirlpool LGR7848DZ1 GAS DRYER
Whirlpool LGR7858AN1 GAS DRYER
Whirlpool LGR7858AN2 GAS DRYER
Whirlpool LGR7858AW0 Residential Dryer
Whirlpool LGR7858AW1 GAS DRYER
Whirlpool LGR7858AW2 GAS DRYER
Whirlpool LGR8620PG0 29"GAS DRYER
Whirlpool LGR8620PG1 29"GAS DRYER
Whirlpool LGR8620PW0 29"GAS DRYER
Whirlpool LGR8620PW1 29"GAS DRYER
Whirlpool LGR8646LG0 RESIDENTIAL DRYER
Whirlpool LGR8648LG1 29"GAS DRYER
Whirlpool LGR8648LQ0 RESIDENTIAL DRYER
Whirlpool LGR8648LW0 RESIDENTIAL DRYER
Whirlpool LGR8648LW1 29"GAS DRYER
Whirlpool LGR8648PG0 29"GAS DRYER
Whirlpool LGR8648PG1 29" Gas Dryer
Whirlpool LGR8648PQ0 29" GAS DRYER
Whirlpool LGR8648PQ1 29" Gas Dryer
Whirlpool LGR8648PW0 29"GAS DRYER
Whirlpool LGR8648PW1 29" Gas Dryer
Whirlpool LGR8857EQ0 GAS DRYER
Whirlpool LGR8857EQ1 DRYERS
Whirlpool LGR8857EQ2 GAS DRYER
Whirlpool LGR8857EQ3 GAS DRYER
Whirlpool LGR8857EZ0 GAS DRYER
Whirlpool LGR8857EZ1 DRYERS
Whirlpool LGR8857EZ2 GAS DRYER
Whirlpool LGR8857EZ3 GAS DRYER
Whirlpool LGR8858DQ0 GAS DRYER
Whirlpool LGR8858DQ1 GAS DRYER
Whirlpool LGR8858DZ0 GAS DRYER
Whirlpool LGR8858DZ1 GAS DRYER
Whirlpool LGR8858EQ0 GAS DRYER
Whirlpool LGR8858EQ1 DRYERS
Whirlpool LGR8858EQ2 GAS DRYER
Whirlpool LGR8858EQ3 GAS DRYER
Whirlpool LGR8858EZ0 GAS DRYER
Whirlpool LGR8858EZ1 DRYERS
Whirlpool LGR8858EZ2 GAS DRYER
Whirlpool LGR8858EZ3 GAS DRYER
Amana LGS10AW WASHER-TOP LOADING
Amana LGS19AW DRYER- GAS
Amana LGS33AW DRYER- GAS
Amana LGS34AW WASHER-TOP LOADING
Frigidaire LGS389FEA Frigidaire/gas Range
Whirlpool LGT5434AQ0 Residential Dryer
Whirlpool LGT5434AW0 Residential Dryer
Whirlpool LGT5436AW0 Residential Dryer
Whirlpool LGT5624BN0 GAS DRYER
Whirlpool LGT5624BN1 GAS DRYER
Whirlpool LGT5624BN2 GAS DRYER
Whirlpool LGT5624BQ0 GAS DRYER
Whirlpool LGT5624BQ1 GAS DRYER
Whirlpool LGT5624BQ2 GAS DRYER
Whirlpool LGT5624BW0 GAS DRYER
Whirlpool LGT5624BW1 GAS DRYER
Whirlpool LGT5624BW2 GAS DRYER
Whirlpool LGT5624DQ0 GAS DRYER
Whirlpool LGT5624DQ1 GAS DRYER
Whirlpool LGT6634AN1 DRYER
Whirlpool LGT6634AN2 GAS DRYER
Whirlpool LGT6634AQ0 GAS DRYER
Whirlpool LGT6634AQ1 GAS DRYER
  #2 (permalink)
Old 11-12-2009, 01:21 PM
Junior Member
e31430 is on a distinguished road
Default
Quote:
I've attached a tech sheet...(Gas Burners)read it and follow instructions. It will fix your issues.Pages 12-14 if this all checks out then check your thermal fuse and thermostats behind the back panel....they should all read
zero ohms.This info is on the tech sheet attachment page 6
If you get stuck let me know.
Good Luck
K
  #3 (permalink)
Old 11-12-2009, 01:41 PM
Junior Member
Default
i couldnt get the gas burner sheet to upload so sent this instead.
K
  #4 (permalink)
Old 11-12-2009, 02:09 PM
Junior Member
Default
How To Check Dryer Parts For Continuity
see administrators post for this info
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper (Gas) Dryer heats up then heat goes off (still running, no heat) jtdesignsca Dryer Repair 3 01-17-2013 12:06 PM
Clothes dryer runs, but doest not heat (Dryer no heat yzhong Dryer Repair 5 10-29-2009 04:54 PM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Gas Dryer tumbles but won't heat. Timer does not move when dryer is started. NEAL AMES Dryer Repair 1 01-02-2009 06:40 PM
Dryer will not heat during timed drying; will heat for short time while auto drying mg13nj Dryer Repair 11 11-11-2008 03:50 PM
