Boxxcarr
#1 Posted : Wednesday, November 11, 2009 2:16:26 PM(UTC)
Boxxcarr
G'Day All!
I've inherited the "Maintenance Man" job for my wife's workplace and require a service manual for a Kenmore Washer/Dryer. Model #
970-C94702-00 , Ser # XE64000567. This appears to be an apartment model as the dryer is mounted over top of the washer.
The trouble appears to be a worn out drum bearing on the dryer as the drum jumps around when starting the dryer. All the movement is in the rear of the assembly.
Does anyone know where a manual for this model may be found??
Thanks All !!
Boxxcarr
sidfink43
#2 Posted : Thursday, November 12, 2009 3:14:33 PM(UTC)
sidfink43
Your model number does not come up. Check it again and reposts. It should start with 110 or 417.
Boxxcarr
#3 Posted : Thursday, November 12, 2009 4:28:17 PM(UTC)
Boxxcarr
Thanks sid,
The model number I posted was a direct copy from the mftr tag on the inside of the door. Serial # directly below that. I will check again this P.M. and repost if it is different. Maybe even add a Pic of that tag and the unit itself if that helps.
Boxxcarr
Boxxcarr
#4 Posted : Monday, November 16, 2009 3:18:06 PM(UTC)
Boxxcarr
Yep, that's the model number. Mftd for Sears Canada in the USA. UPC code directly above that Mod # and another UPC code above the Ser # ( located directly below the Mod #). No other mftr tags that I can find. This tag was on the inside of the dryer door. Again, it's an aprtment type, all in one, dryer mounted above the washer. Tried to get a Pic of the tag but my digital cam wouldn't focus in that tight, unable to read it from further back. I might have access to a better dig cam through the week. If so, I'll try a pic of the tag once more.
sidfink43
#5 Posted : Monday, November 16, 2009 3:33:29 PM(UTC)
sidfink43
Ok, If I had been even half awake I would have recognized your Canadian model, particularly since I spent 25 years in Buffalo and could see Canada from my house.
Here is a service manual which should match up pretty closely with your machine. Let us know if it does so we can advise others.
http://frigidaireservicetips.com/pdfs/488_3.pdf
Kenmore Washer/Dryer Combo Model 110.88752794 (Washer Repair)
by SMBrian 4/22/2019 6:28:33 AM(UTC)
Kenmore washer/dryer combo installation instructions (Washer Repair)
by hollyinrio 6/14/2012 4:29:00 PM(UTC)
Kenmore Washer/dryer combo (Washer Repair)
by dbscotties 11/29/2011 7:46:48 PM(UTC)
kenmore washer/dryer combo (Washer Repair)
by vbc999 11/14/2011 12:09:02 PM(UTC)
Kenmore washer/dryer combo (Dryer Repair)
by kwp 10/12/2009 9:54:03 AM(UTC)
Kenmore Washer/Dryer combo won't drain or spin (Washer Repair)
by uttdawg 5/26/2009 11:07:57 AM(UTC)
