Discuss
kenmore 80 series dryer won't heat
 in
Dryer Repair
My dryer dried one load of clothes, went to put in another load and it was all cool air no
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » kenmore 80 series dryer won't heat
  #1 (permalink)
Old 11-10-2009, 12:36 PM
Junior Member
Dhodge is on a distinguished road
Default kenmore 80 series dryer won't heat
Model Number: 11066812690   Brand: Kenmore   Age: 5 - 10 years
My dryer dried one load of clothes, went to put in another load and it was all cool air no heat, I have checked the air to make sure it was not on air and I cleaned out the lint vent and hose so that is all clear, help????
Related Models
Kenmore 11066812690 ELECTRIC DRYER
Kenmore 11066812691 ELECTRIC DRYER
Kenmore 11066812692 ELECTRIC DRYER
Kenmore 11066812694 ELECTRIC DRYER
Kenmore 11066814690 ELECTRIC DRYER
Kenmore 11066814691 ELECTRIC DRYER
Kenmore 11066814692 ELECTRIC DRYER
Kenmore 11066814694 ELECTRIC DRYER
Kenmore 11066822690 SUPER CAPACITY PLUS CLOTHES DRYER
Kenmore 11066822691 ELECTRIC DRYER
Kenmore 11066822692 Residential Dryer
Kenmore 11066822694 ELECTRIC DRYER
Kenmore 11066824690 ELECTRIC DRYER
Kenmore 11066824691 ELECTRIC DRYER
Kenmore 11066824692 Residential Dryer
Kenmore 11066824694 ELECTRIC DRYER
Kenmore 11066832500 DRYER
Kenmore 11066832501 RESIDENTIAL DRYER
Kenmore 11066842500 DRYER
Kenmore 11066842501 RESIDENTIAL DRYER
Kenmore 11066852690 ELECTRIC DRYER
Kenmore 11066852691 ELECTRIC DRYER
Kenmore 11066852692 Residential Dryer
Kenmore 11066852694 ELECTRIC DRYER
Kenmore 11066854690 ELECTRIC DRYER
Kenmore 11066854691 ELECTRIC DRYER
Kenmore 11066854692 ELECTRIC DRYER
Kenmore 11066854694 ELECTRIC DRYER
Kenmore 11066862500 DRYER
Kenmore 11066862501 RESIDENTIAL DRYER
Kenmore 11066864500 DRYER
Kenmore 11066864501 RESIDENTIAL DRYER
Kenmore 11066872500 RESIDENTIAL DRYER
Kenmore 11066872501 RESIDENTIAL DRYER
Kenmore 11066901690 SUPER CAPACITY PLUS DRYER
Kenmore 11066901691 ELECTRIC DRYER
Kenmore 11066901692 ELECTRIC DRYER
Kenmore 11066902690 ELECTRIC DRYER
Kenmore 11066902691 ELECTRIC DRYER
Kenmore 11066902692 ELECTRIC DRYER
Kenmore 11066904690 ELECTRIC DRYER
Kenmore 11066904691 ELECTRIC DRYER
Kenmore 11066904692 ELECTRIC DRYER
Kenmore 11066912690 SUPER CAPACITY PLUS CLOTHES DRYER
Kenmore 11066912691 ELECTRIC DRYER
Kenmore 11066912692 ELECTRIC DRYER
Kenmore 11066914690 ELECTRIC DRYER
Kenmore 11066914691 ELECTRIC DRYER
Kenmore 11066914692 ELECTRIC DRYER
Kenmore 11066922500 RESIDENTIAL DRYER
Kenmore 11066922501 RESIDENTIAL DRYER
Kenmore 11066924500 RESIDENTIAL DRYER
Kenmore 11066924501 RESIDENTIAL DRYER
Kenmore 11066926500 RESIDENTIAL DRYER
Kenmore 11066926501 RESIDENTIAL DRYER
Kenmore 11066932690 ELECTRIC DRYER
Kenmore 11066932691 ELECTRIC DRYER
Kenmore 11066934690 ELECTRIC DRYER
Kenmore 11066934691 ELECTRIC DRYER
Kenmore 11066942500 DRYER
Kenmore 11066942501 RESIDENTIAL DRYER
Kenmore 11066944500 DRYER
Kenmore 11066944501 RESIDENTIAL DRYER
Kenmore 11066952691 ELECTRIC DRYER
Kenmore 11066954690 ELECTRIC DRYER
Kenmore 11066954691 ELECTRIC DRYER
Kenmore 11066955690 ELECTRIC DRYER
Kenmore 11066955691 ELECTRIC DRYER
Kenmore 11066962500 DRYER
Kenmore 11066962501 RESIDENTIAL DRYER
Kenmore 11066964500 RESIDENTIAL DRYER
Kenmore 11066964501 RESIDENTIAL DRYER
Kenmore 11066966500 DRYER
Kenmore 11066966501 RESIDENTIAL DRYER
Kenmore 11066972500 DRYER
Kenmore 11066972501 RESIDENTIAL DRYER
Kenmore 11066982500 DRYER
Kenmore 11066982501 RESIDENTIAL DRYER
Kenmore 11066992500 DRYER
Kenmore 11066992501 RESIDENTIAL DRYER
Kenmore 11066994500 DRYER
Kenmore 11066994501 RESIDENTIAL DRYER
Kenmore 11066996500 DRYER
Kenmore 11066996501 RESIDENTIAL DRYER
Kenmore 1106701100 KENMORE WRINGER WASHER
Kenmore 1106701110 KENMORE WRINGER WASHER
Kenmore 1106702100 KENMORE WRINGER WASHER
Kenmore 1106702110 KENMORE WRINGER WASHER
Kenmore 1106702300 KENMORE WRINGER WASHER
Kenmore 1106702301 KENMORE WRINGER WASHER
Kenmore 1106702310 KENMORE WRINGER WASHER
Kenmore 1106702500 KENMORE WRINGER WASHER
Kenmore 1106702501 KENMORE WRINGER WASHER
Kenmore 1106702600 KENMORE WRINGER WASHER
Kenmore 1106702601 KENMORE WRINGER WASHER
Kenmore 1106702640 KENMORE WRINGER WASHER
Kenmore 1106702700 KENMORE WRINGER WASHER
Kenmore 1106702701 KENMORE WRINGER WASHER
Kenmore 1106702900 KENMORE WRINGER WASHER
Kenmore 1106702901 KENMORE WRINGER WASHER
Kenmore 1106702910 KENMORE WRINGER WASHER
Kenmore 1106703100 KENMORE AUTOMATIC WASHER
Kenmore 1106703101 KENMORE AUTOMATIC WASHER
Kenmore 1106703102 KENMORE AUTOMATIC WASHER
Kenmore 1106703103 KENMORE AUTOMATIC WASHER
Kenmore 11067032600 DRYER
Kenmore 11067032601 RESIDENTIAL DRYER
Kenmore 1106703400 KENMORE AUTO WASHER NON-SUDS MODEL
Kenmore 1106703401 KENMORE AUTOMATIC WASHER
Kenmore 1106703402 KENMORE AUTOMATIC WASHER
Kenmore 1106703403 KENMORE AUTOMATIC WASHER
Kenmore 1106703500 KENMORE AUTO WASHER NON-SUDS MODEL
Kenmore 1106703501 KENMORE AUTOMATIC WASHER
Kenmore 1106703502 KENMORE AUTOMATIC WASHER
Kenmore 1106703503 KENMORE AUTOMATIC WASHER
Kenmore 1106704000 KENMORE AUTOMATIC WASHER
Kenmore 1106704001 KENMORE AUTOMATIC WASHER
Kenmore 1106704002 KENMORE AUTOMATIC WASHER
Kenmore 1106704050 KENMORE AUTOMATIC WASHER
Kenmore 1106704051 KENMORE AUTOMATIC WASHER
  #2 (permalink)
Old 11-11-2009, 09:12 PM
Senior Member
Qtip is on a distinguished road
Default
First use a meter to test the outlet for 240. the dryer itself will run with 120 but needs 240 for the heater to work - sometimes half of the line will trip (if you only read 120 then flip the breaker and that should reset it) if full 240 is there then check cord connections to dryer (will have a few screws holding on a cover plate that covers up the connections). if those wires are fine and not burnt up or corroded then check the heating element for continuity (if u have continuity it is ok)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 series - No heat, won't shut off c1eddy Dryer Repair 17 07-08-2017 09:24 AM
dryer will heat but not spin- kenmore 70 series model abengoa Dryer Repair 1 09-14-2009 08:54 PM
Kenmore dryer 80 series jinks7 Dryer Repair 1 07-09-2009 02:52 PM
Kenmore gas Dryer 60 Series ReneD Dryer Repair 3 02-09-2008 10:03 PM
Kenmore 60 Series(gas) Runs but wont heat PJM Dryer Repair 0 02-02-2008 06:09 AM
