| » GE Profile Repair Question |
Model Number: DPSR473GW0WW Brand: GE Age: More than 10 years
I have a GE Profile Dryer - DPSR473GW0WW.
Belt is snapped. I found that the front drum bearing is broken. At a minimum I need to replace the belt, drum bearing and drum slides. Should I replace the felt also? AP3790641 Front Drum Bearing (313) AP2041815 Dryer Drum Slide (316) X 2 AP4324040 Belt AP4319934 Felt Anything else I should consider replacing (other than the whole dryer) since I have the dryer apart? What about repair or preventative maintenance manuals - are they available online? Thanks in advance for any help, Dan Ads By Google Related Models |
Dan,
I would also check the rear drum bearing. Very likely it's worn out as well. Make sure all air ducts and the blower wheel are clean. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Is adhesive required to attach the felt for this dryer?
I have performed maintenance on this dryer before by removed the front panel. Is the removal of the side panels difficult - must be one "hidden" screw - can't seem to get the panel off. What about grease for the bearing - any recommendations? What about repair manuals - any place on the web to find them? |
Quote:
- The high temperature adhesive Part number: AP4284239 Quote:
Quote:
Quote:
- The GE dryers repair manual Part number: AP3148136 Here are the breakdown diagrams and Replacement parts for GE DPSR473GW0WW | AppliancePartsPros.com Gene.
__________________
I picked up a belt from the local appliance repair store, but I attempted to install the belt and it appears to be way too long. I checked the part number AP4324040 and was giving a replacement part number of WE12M29 - appears to be OK. What am I doing wrong?
The following belt diagram might help.
![]() Gene.
__________________
| Display Modes | |
| Refrigerator repair question | bthlonewolf | Refrigerator & Freezer Repair | 15 | 10-13-2011 08:46 AM |
| Repair question | Mark Weidner | Washer Repair | 1 | 01-18-2010 07:30 AM |
| Repair question | rsingh2483 | Refrigerator & Freezer Repair | 1 | 02-22-2009 05:10 PM |
| Help with a repair question | jillc | Oven Repair (including Ranges and Cooktops) | 2 | 02-21-2009 01:36 PM |
| GE Profile drain plug question? | rvcmike | Refrigerator & Freezer Repair | 0 | 02-01-2009 06:33 AM |
