Discuss
Dryer does not start
 in
Dryer Repair
I'm not a savvy with fixing dryers at all. Problem: Dryer does not work when start button is selected.
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer does not start
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-25-2008, 07:13 PM
jamn424 jamn424 is offline
Junior Member
jamn424 is on a distinguished road
Default Dryer does not start
Model Number: FEFB9200ES   Brand: Frigidaire   Age: 1 - 5 years
Problem:
Dryer does not work when start button is selected. All I hear beeps, but it does not spin at all.
Fact:
When pressing button on control panel, I hear sound and beeps at every button selection. It's a digital panel.
Any help would be really appreciated. I've replaced thermal limiter but that didnt do anything. Any help would be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-26-2008, 03:54 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
The first thing I would check if there is 240V at the power outlet.
If there is nothing wrong, remove the bottom panel and look for an envelope with the tech sheets. Perform the troubleshooting according to the instructions from the tech sheets.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 04-06-2008, 09:26 AM
jimbrown jimbrown is offline
Junior Member
jimbrown is on a distinguished road
Default same problem
I'm having the same problem. It's been a month or so since you posted the above, so I'm wondering if you've had any luck with repairing this problem.
I'm wondering if it's perhaps a problem with the thermal limiter, but that's just a guess based on some of the reading on the web and the manual.
Did you have any success with resolving your problem?
  #4 (permalink)
Old 04-07-2008, 03:52 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
You both will need a meter to check things, otherwise we all are just making guesses.
__________________
  #5 (permalink)
Old 04-08-2008, 08:20 AM
Junior Member
Default solution?
I broke down and called a repairman. He said the problem is the temperature control mechanism. He used an ohmeter to test the current (after looking at the electrical diagram for the dryer to find the right wiring to test) which indicated that it was indeed the problem. If our problems are the same and you know your way around an electrical diagram, I would download the diagram from the Frigidaire site (for this specific dryer) and find the temp control wiring and use an ohmeter to test this.
Good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer won't start Beagle Dryer Repair 0 02-12-2008 05:00 PM
Dryer won't start milisa Dryer Repair 0 12-18-2007 06:22 PM
Dryer won't start shangki Dryer Repair 1 12-17-2007 08:16 PM
Dryer will not start - sometimes stripe5 Dryer Repair 1 11-26-2007 06:45 PM
Dryer will not start bob38 Dryer Repair 2 09-19-2007 07:59 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
