| » Electric Dryer Repair |
Model Number: 110.62822101 Brand: Kenmore Age: 1 - 5 years
Dear Sir:
I have an electric dryer with no heat. I have changed out all the thermostats, heater element, thermal fuse. All have good conductivity the only part I have not replaced is the pad sensor. What is the purpose of the pad sensor and will it rectify my problem? Ads By Google Related Models |
Quote:
Here is the wiring diagram
http://www.servicematters.com/docs/w...%203406659.pdf I have changed out all the thermostats, heater element, thermal fuse. Sounds like it is time to buy a meter as plug and chug is costing you a fortune. All have good conductivity the only part I have not replaced is the pad sensor. What is the purpose of the pad sensor and will it rectify my problem? I doubt it as this controls the timer. If the sensor detects moisture it holds the timer off. Have you tried flipping the beaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker and the heater requires both sides. Better yet measure it at the plug. L1 to L2 should be 240 volts. L1 to Neutral and L2 to Neutral both should be 120 volts. If OK Check the terminal strip to be sure a wire has not burned off Unplug the unit Set the unit to timed dry mid cycle. Set the meter to it's lowest ohms scale re: 200 Place/tape one lead to L1. You can do this at the timer or on the line cord. Then work your way through the heating circuit. So the first measurement is to R on the timer, should be 0 ohms. Then R at the thermal cutoff should be 0 ohms. All should be 0 ohms till you get to the heater then the far side of the heater should give you 10 ohms approximately. If all the above is OK you either have a burned out wire, a power problem or the centrifugal switch is not working.
__________________
- Last edited by denman : 11-10-2009 at 05:26 AM. |
| Display Modes | |
| Electric Oven Issue - Worth Repair?? | ibdavid | Oven Repair (including Ranges and Cooktops) | 22 | 01-25-2013 06:14 PM |
| oven repair electric | Rush | Oven Repair (including Ranges and Cooktops) | 0 | 04-13-2009 05:09 AM |
| Electric Dryer Repair | lming | Dryer Repair | 4 | 10-03-2008 01:54 PM |
| GE electric oven repair parts | mikesawa | Oven Repair (including Ranges and Cooktops) | 0 | 09-29-2008 09:56 AM |
| Electric cooktop repair | loud1123 | Oven Repair (including Ranges and Cooktops) | 1 | 01-28-2008 01:41 PM |
