| » Won't heat or gas shuts off after ignition |
Model Number: MDG9700A Brand: Maytag Age: 1 - 5 years
I've checked all the electrical components with my ohmmeter and the they all are within spec. according to the information sheet that came with the dryer. The ignition cycle works every time. The gas, however, initially comes on then goes out; after that, it doesn't come on at all.
I'm guessing maybe the thermostat (I hope it isn't the valves) is the problem, but I hate to troubleshoot it by throwing parts at it. Any suggestions on how to narrow this down further? Much appreciated. Related Models Last edited by Ben Lurkin : 11-08-2009 at 01:06 AM. |
No responses? Figures. . . .
After talking with the local parts guys, here's how one decides if it's the thermostat or the coils when they all test 'good' with the ohmmeter. . . This assumes the ignitor cycle is functioning properly as noted above in my initial post. Remove the thermostat. with the ohmmeter, check to ensure continuity while it is cool. With the meter still attached, heat the metal disk with a lighter (be careful not to burn yourself) for a few monents. You should hear an audible click and the meter will show the circuit as open. Let it cool for a bit and it will close the circuit again if it is functioning properly as shown on the ohmmeter. So this is just an on-off switch controlled by heat. If this checks out, it is the coils; even if they read ok with the ohmmeter. They explained they occasionally break down shortly after current is applied and therefore will not operate the valves properly. This was the problem in my case. Note that MAYTAG does not sell a coil kit for their dryers. However, all the manufacturers apparently use the same valve and the coil kits are available from other applications. They were a whole $16 for both the three and two-prong coils. Hopefully this helps someone else. |
Just wanted to say thank you for sharing your diagnosis and repair with us. Your post was very illuminating and instructive. Good luck with your dryer.
__________________
Professional appliance repair in Orange County, California. |
| Display Modes | |
| Normal Heat Empty, Heat Shuts Off Full | BigDaddyG | Dryer Repair | 4 | 08-06-2009 04:17 PM |
| Heat Shuts Off After 20 Seconds | cdcamp | Dryer Repair | 1 | 05-28-2009 07:17 PM |
| heat starts then shuts off | brick 1 | Dryer Repair | 1 | 03-15-2009 07:11 AM |
| heat dryer shuts down | basketballcoach322 | Dryer Repair | 2 | 12-24-2008 03:33 PM |
| no heat and shuts down less 30 seconds | dhardie | Microwave Repair | 2 | 05-03-2008 09:44 PM |
