Discuss
Maytag Electric dryer - Heater element comes on then quits
 in
Dryer Repair
electric dryer heater element comes on then quits I would suspect the thermostat is bad. would part # AP4242472 Fix the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Electric dryer - Heater element comes on then quits
  #1 (permalink)
Old 11-06-2009, 09:51 PM
Larry Goldman Larry Goldman is offline
Junior Member
Larry Goldman is on a distinguished road
Thumbs up Maytag Electric dryer - Heater element comes on then quits
Model Number: PYE2000AYW   Brand: Maytag   Age: 5 - 10 years
would part # AP4242472 Fix the problem?
Thermostat Kit / $ 18.65
53-0771
Related Models
Maytag PYE2000AYW Dryer - Ele
Maytag PYE2000AZW Dryer - Ele
International PYE2000GGE Dryer - Ele
International PYE2200AKW Dryer - Ele
Maytag PYE2200AYW Dryer - Ele
Maytag PYE2200AZW Dryer - Ele
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
  #2 (permalink)
Old 11-07-2009, 06:20 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYE2000AYW | AppliancePartsPros.com
would part # AP4242472 Thermostat Kit / $ 18.65
Fix the problem?
I cannot say.
This is the high limit thermostat with a thermal fuse.
The actual cycling thermostat is Item 14 in Section 5 on the units blower housing. Note: this tstat has an internal heater which is turned on to provide lower machine temperatures. So make sure to note which wire goes where as there are 4 wires.
I am assuming that the drum continues to run.
Have you tried different cycle types and temperatures to see if there are any differences?
Either the Safety Thermostat (Hi-limit) or the Thermostat (Cycling) could cause your problem but so can some other things..
I would try the following first:
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
Also clean/check the blower wheel.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
__________________
  #3 (permalink)
Old 11-07-2009, 05:31 PM
Junior Member
Default
53-0771
I purchased the kit
I replaced the Thermostat and the other sensor for electric dryers.
but the problem remains.
The heater element comes on and then the therostat kicks it off just as the heater element begins to glow red hot ?
The vent is clean.
  #4 (permalink)
Old 11-07-2009, 06:12 PM
Senior Expert
APP Volunteer
Default
Which thermostat did you buy operating (cycling ) or the hi-limit?
How do you know the thermostat is kicking shutting it off?
And which thermostat is shutting it off?
Note that just because the vent is clean does not mean that you have good air flow over the heating coil.
Things that can effect this are:
Dirty or loose blower wheel
A lint filter that is coated with fabric softener residue
A seal or gasket that is leaking.
You are actually sucking the air over the coil and through the drum so any large air leak in the system will reduce the air traveling over the coil causing it to overheat.
Also does the coil heat up fairly evenly. Sometimes a coil can break and touch the case depending how/where is breaks it can get very hot and cause an over heat condition.
__________________
  #5 (permalink)
Old 11-07-2009, 06:41 PM
Junior Member
Default
Yes the coil heats up evenly.
I purchased # LA-1053-thermostat / fuse kit adm
It appears that the thermostat that sits above the heater element "clicks" out and shuts down the heater coil.
I can see this happen when i lift the lid on the dryer and watch the coil come on..glow red then "click" it goes out.
I also replaced the Hi-limit switch "pink dot"
Thanks.
  #6 (permalink)
Old 11-08-2009, 03:22 AM
Senior Expert
APP Volunteer
Default
Does sound like either an air flow problem or the operating thermostat's (Item 14 in Section 5) contacts are welded together.
If you have checked the air flow/seals I would replace the operating thermostat.
You could check it by heating it up. I use my soldering gun to heat it's face plate you could also heat it up on a stove element and see if it opens.
Be sure to mark where it's wires go as it is a 4 wire thermostat.
__________________
  #7 (permalink)
Old 11-10-2009, 08:54 PM
Junior Member
Default
Yes..Yesterday i replaced this...same problem, but !!!!!!!!
Now I noticed after checking the amount of air coming out of the dryer "0"
that i could feel...that after opening the front again I noticed the Blower Wheel was "wobbleing" on the shaft...bingo a cracked blower wheel that had gouges on the blade and it was sliding on the shaft.
I will replace this tomorrow and see if this solves the problem. Let you know.
Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
40 Gal. Dual Element Electric Hot Water Heater Teager Heating, Ventilation, and Air Conditioning (HVAC) 4 09-13-2009 06:21 AM
Also Need Heater Element 31001746 for Maytag Dryer Hperez54 Dryer Repair 1 08-16-2009 06:40 PM
Maytag Dryer quits tumbling after a few minutes CinderMom Dryer Repair 4 07-29-2009 04:35 PM
Kenmore Electric Dryer heater won't shut off jmd_forest Dryer Repair 6 03-25-2009 09:22 AM
Heater Element GE Dryer scottskicooper Dryer Repair 2 03-05-2009 09:43 AM
