Discuss
Motor hums,but won't start
 in
Dryer Repair
Problem: Dry cycle would start and stop at different times during the cycle. At times it would complete the cycle,
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Motor hums,but won't start
  #1 (permalink)
Old 11-06-2009, 11:31 AM
Richpeterson Richpeterson is offline
Junior Member
Richpeterson is on a distinguished road
Default Motor hums,but won't start
Model Number: PYE2200AYW   Brand: Maytag   Age: 5 - 10 years
Problem: Dry cycle would start and stop at different times during the cycle. At times it would complete the cycle, or if we waited awhile it could be restarted. Now when we engage the cycle the motor hums and won't start. It was suggested that it could be the heat sensor. The motor ran fine when it did. The machine is ten years old. Your thoughts?
Related Models
Maytag PYE2200AYW Dryer - Ele
Maytag PYE2200AZW Dryer - Ele
Maytag PYE2300AYW Dryer - Ele
Maytag PYE2300AZW Dryer - Ele
International PYE3200AGW Dryer - Ele
Maytag PYE3200AYW Dryer - Ele
Maytag PYE3200AZW Dryer - Ele
International PYE3300AGW Dryer - Ele
International PYE3300AKW Dryer - Ele
Maytag PYE3300AYW Dryer - Ele
Maytag PYE3300AZW Dryer - Ele
Maytag PYE3360AYW Dryer - Ele
Maytag PYE4500AYQ Dryer - Ele
Maytag PYE4500AYW Dryer - Ele
Maytag PYE4500AZW Dryer - Ele
Maytag PYE4557AYW Dryer - Ele
Maytag PYE4558AYW Dryer - Ele
Maytag PYET244AYW Dryer - Ele
Maytag PYET244AZW Dryer - Ele
Maytag PYET344AYQ Dryer - Ele
Maytag PYET344AYW Dryer - Ele
Maytag PYET344AZW Dryer - Ele
Maytag PYET444AYQ Dryer - Ele
Maytag PYET444AYW Dryer - Ele
Maytag PYET444AZW Dryer - Ele
Maytag PYG1000AWW Dryer - Gas
Maytag PYG2000AWW Dryer - Gas
Maytag PYG2200AWW Dryer - Gas
International PYG2300AGW Dryer - Gas
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
  #2 (permalink)
Old 11-07-2009, 06:31 AM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here are your parts includes a wiring diagram
Replacement parts for MAYTAG PYE2200AYW | AppliancePartsPros.com
No, this will have no effect on the starting of the motor.
Sounds like your motor is toast but there are a couple things I would do first
1. Try rotating the drum by hand in the correct direction , it should turn fairly easily. If not perhaps that is preventing the drum from rotating.
2. Open the unit up and check/clean the motor.
The motor has 2 centrifugal switches on it. One of them is for the start winding if this switch does not reset, then the start winding is not in circuit when the motor is at rest and it will just hum.
Both the above are long shots.
Odds are high you need a new motor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leak at back of motor/motor just hums rgtrev Dishwasher Repair 0 09-21-2009 03:17 PM
whirlpol dryer won't start-just hums when I push the start button bdubois Dryer Repair 10 09-17-2009 05:38 PM
Motor Hums But Will Not Start dstraple Washer Repair 5 02-18-2009 05:01 AM
Maytag Dependble - No Spin/Drain, Motr Hums - Belt Cn Be Rotatd by Hand 2 Start Motor bluestreak Washer Repair 12 12-06-2008 02:53 AM
Gas dryer motor hums but won't start nonqual Dryer Repair 5 12-27-2007 05:40 AM
