Discuss
Kenmore Gas Dryer - No Heat
 in
Dryer Repair
Hello, hoping for some guidance here. I have the above dryer and the igniter is not lighting at all. Clothes
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Kenmore Gas Dryer - No Heat
  #1 (permalink)
Old 10-06-2018, 06:55 PM
Junior Member
smackover is on a distinguished road
Default Kenmore Gas Dryer - No Heat
Model Number: 110.74982300   Brand: Kenmore   Age: More than 10 years
Hello, hoping for some guidance here. I have the above dryer and the igniter is not lighting at all. Clothes have been taking a long time to dry the past couple of weeks and finally no heat today.
I have checked continuity on the following items and all have checked out okay.
1. Thermal fuse checks out okay
2. Igniter (reads 75 ohms)
3. Gas solenoids tested good. I replaced anyway but no change
4. Flame sensor checks out okay
5. High limit thermostat checks out okay
6. Cycling thermostat. I can't find it to check it. Haven't taken the dryer completely apart yet.
7. Thermistor (adjacent to the thermal fuse) reads about 9 ohms
Questions:
1. Is there a cycling thermostat on my dryer? I assume there is as the unit has several heat settings.
2. Can the igniter test good and be bad?
Please help.
Cameron
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 10-08-2018, 11:27 AM
Junior Member
Default
Anyone?
I did more troubleshooting over the weekend and here is where I'm at now:
1. Bench tested the igniter and it lights
2. Thermister reads between 9-10 ohms
3. Thermal fuse, gas solenoids, HL Thermo test okay.
I even went so far as to take the centrifigal switch apart at the motor and clean the contacts.
I still don't have a glowing igniter when starting the dryer. I'm at a complete loss as to where to go from here.
Any assistance is greatly appreciated.
  #3 (permalink)
Old 10-08-2018, 05:45 PM
Junior Member
Billy889 is on a distinguished road
Default
Up! Good One
  #4 (permalink)
Old 10-09-2018, 12:07 AM
Junior Member
Default
I finally found the problem. It was the heater relay switch up in the control housing. I found a troubleshooting guide online that suggested checking the relay switch if all the switches and thermostats check out okay.
I’m surprised there was limited information on the relay switch online. It’s probably because they don’t fail for a very long time and the issue is generally one of the 5 switches/thermostat.
To test the relay just swap the start button relay with the heater relay (they are the same exact relay) and see if you get heat. You have to hold the start button down by hand because it’s the only way the dryer will stay running with the faulty relay now being used by the start button. I hope this information helps someone.
  #5 (permalink)
Old 10-11-2018, 06:55 PM
ohm ohm is offline
Senior Member
ohm is on a distinguished road
Default
Part number: WP3405281
This was the part that he replaced! Tech sheet for future problems or other people with the same Model!
File Type: pdf 110.74982300 Tech Sheet - 8545909 - Rev A.pdf (467.6 KB, 0 views)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer no heat joshwlf Dryer Repair 11 01-22-2013 10:34 AM
Kenmore Dryer won't heat farmerjack Dryer Repair 1 06-05-2012 02:44 AM
Kenmore Dryer - Timer not moving with No heat and dryer does not shut off poslow Dryer Repair 2 11-21-2010 10:10 PM
Kenmore dryer heats on low heat but not on high heat Mrhollywood334 Dryer Repair 0 09-11-2010 09:33 PM
Kenmore dryer ~No heat `and more cassjo Dryer Repair 1 01-15-2008 04:14 PM
