Discuss
Gas dryer flame is orange and blue
 in
Dryer Repair
It wasn't getting warm. Replaced the "Dryer Gas Valve Coil Kit" and the "High Limit Thermostat" Cleaned the "Burner Tube
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Gas dryer flame is orange and blue
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-01-2018, 05:25 PM
Junior Member
OlderSurferDude is on a distinguished road
Default Gas dryer flame is orange and blue
Model Number: MDG4057BWW   Brand: Maytag   Age: More than 10 years
Cleaned the "Burner Tube Assembly"
No exhaust blockage (ran with door open)
No apparent intake blockage (gets hot when there's a flame)
The symptoms remain: The "Flat Style Dryer Igniter" glows, the gas comes on ignites, and in less than a minute the "High Limit Thermostat" clicks off and the flame stops. If I continue to let it run (without flame), the "High Limit Thermostat" reconnects and in a short bit of time the cycle repeats.
I shorted the "High Limit Thermostat" and the flame would continue, but, of course, it would get too hot.
I noticed two things about the flame. It seemed a little wild, lapping "High Limit Thermostat". Also, the flame was about 1/2 orange, which indicates incomplete combustion. The latter is not good as that is a source of carbon monoxide.
Could it be that there is too much gas? In trying to figure out how to reduce the gas flow, I found a screw on top of the "Dryer Gas Valve", which I loosened and it came real loose. I didn't want to mess with that so I re-tightened it. Is that just a cap to the pressure adjustment? If so, can I back off the gas? If there is an adjustment screw under the suspected cap screw, do I turn it clockwise or counter-clockwise to diminish the gas flow?
Is this dryer repairable?
Related Models
Maytag MDG4057BWW DRYER- GAS
Frigidaire MDG436MBW0 Kel(v27) / 27 " Gas Dryer
Frigidaire MDG436RBD0 Frg(v2) / 27 " Gas Dryer
Frigidaire MDG436RBD1 Kel(v3) / Gas Dryer
Frigidaire MDG436RBD2 Gib(v11) / Gas Dryer
Frigidaire MDG436RBW0 Tap(v10) / 27 " Gas Dryer
Frigidaire MDG436RBW1 Kel(v4) / Gas Dryer
Frigidaire MDG436RBW2 Gib(v12) / Gas Dryer
Frigidaire MDG436RED0 Frg(v1) / Gas Dryer
Frigidaire MDG436RED1 Frg(v1) / Gas Dryer
Frigidaire MDG436REW0 Frg(v2) / Gas Dryer
Frigidaire MDG436REW1 Frg(v2) / Gas Dryer
Maytag MDG4658AWW DRYER- GAS
Maytag MDG4806AWW DRYER- GAS
Maytag MDG4916AWA DRYER- GAS
Maytag MDG4916AWW DRYER- GAS
Maytag MDG5000BWQ DRYER- GAS
Maytag MDG5000BWW DRYER- GAS
Maytag MDG508DAWK DRYER- GAS
Maytag MDG508DAWW DRYER- GAS
Maytag MDG50MNAWW MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50MNVWQ COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50MNVWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PN1AL MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50PN1AW MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50PN2VW MAYTAG COMMERCIAL DRYER (DRYER GAS)
Maytag MDG50PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PNTVQ MAYTAG LAUNDRY COMMERCIAL (DRYER GAS)
Maytag MDG50PNTVW MAYTAG LAUNDRY COMMERCIAL (DRYER GAS)
Maytag MDG50PNVWQ COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG50PNVWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PDAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PDSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG51PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Frigidaire MDG546RED0 Frg(v1) / Gas Dryer
Frigidaire MDG546RED1 Frg(v1) / Gas Dryer
Frigidaire MDG546RES0 Frg(v2) / Gas Dryer
Frigidaire MDG546RES1 Frg(v2) / Gas Dryer
Frigidaire MDG546RES2 Frg(v0) / Dryer
Frigidaire MDG546RET0 Frg(v3) / Gas Dryer
Frigidaire MDG546REW0 Frg(v4) / Gas Dryer
Frigidaire MDG546REW1 Frg(v3) / Gas Dryer
Maytag MDG5500AWQ DRYER- GAS
Maytag MDG5500AWW DRYER- GAS
Maytag MDG5806AWK DRYER- GAS
Maytag MDG5806AWW DRYER- GAS
Maytag MDG5960BWW DRYER- GAS
Maytag MDG6000AWQ DRYER- GAS
Maytag MDG6000AWW DRYER- GAS
Maytag MDG6000AXW DRYER- GAS
Maytag MDG6000BWQ DRYER- GAS
Maytag MDG6000BWW DRYER- GAS
Maytag MDG6200AWQ DRYER- GAS
Maytag MDG6200AWW DRYER- GAS
Maytag MDG6400AWQ DRYER- GAS
Maytag MDG6400AWW DRYER- GAS
Maytag MDG6460AWW DRYER- GAS
Maytag MDG6657BWQ DRYER- GAS
Maytag MDG6657BWW DRYER- GAS
Maytag MDG6700AWM DRYER- GAS
Maytag MDG6700AWW DRYER- GAS
Maytag MDG6800AWQ DRYER- GAS
Maytag MDG6800AWW DRYER- GAS
Maytag MDG7057AWQ DRYER- GAS
Maytag MDG7057AWW DRYER- GAS
Maytag MDG7057BWQ DRYER- GAS
Maytag MDG7057BWW DRYER- GAS
Maytag MDG7400AWQ DRYER- GAS
Maytag MDG7400AWW DRYER- GAS
Maytag MDG7460AWQ DRYER- GAS
Maytag MDG7460AWW DRYER- GAS
Maytag MDG7500AWQ DRYER- GAS
Maytag MDG7500AWW DRYER- GAS
Maytag MDG75MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MDG75MNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75MNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PN1AW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PN2VW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNAVW MANUAL, PARTS (DRYER GAS)
Maytag MDG75PNHWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNHWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVVW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWQ MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG75PNVWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7600AWQ DRYER- GAS
Maytag MDG7600AWW DRYER- GAS
Maytag MDG7657AWQ DRYER- GAS
Maytag MDG7657AWW DRYER- GAS
Maytag MDG7657BWQ DRYER- GAS
Maytag MDG7657BWW DRYER- GAS
Maytag MDG7658AWQ DRYER- GAS
Maytag MDG7658AWW DRYER- GAS
Maytag MDG7658BWQ DRYER- GAS
Maytag MDG7658BWW DRYER- GAS
Maytag MDG76PCBWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG76PCBWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG7757AWQ DRYER- GAS
Maytag MDG7757AWW DRYER- GAS
Maytag MDG7758AWQ DRYER- GAS
Maytag MDG7758AWW DRYER- GAS
Maytag MDG77PNAWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG77PNSWW COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MDG8000AWQ DRYER- GAS
Maytag MDG8000AWW DRYER- GAS
Maytag MDG8000BWQ DRYER- GAS
Maytag MDG8000BWW DRYER- GAS
Maytag MDG8057AWQ DRYER- GAS
Maytag MDG8057AWW DRYER- GAS
Maytag MDG8057BWQ DRYER- GAS
Maytag MDG8057BWW DRYER- GAS
Maytag MDG8058BWQ DRYER- GAS
Maytag MDG8058BWW DRYER- GAS
Maytag MDG8400AWQ DRYER- GAS
Maytag MDG8400AWW DRYER- GAS
Maytag MDG8416AWA DRYER- GAS
Maytag MDG8416AWW DRYER- GAS
Admiral MDG8426AAW DRYER- GAS
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Admiral gas dryer little flame at spreader, then flame at air mix port only Ocdryer Dryer Repair 3 02-16-2017 11:56 PM
HELP !Where to connect Orange,White,Blue wire on Relay tiffkbjf Refrigerator & Freezer Repair 0 11-05-2014 12:33 PM
Gas Range with blue orange flames on all burners steve 23 Oven Repair (including Ranges and Cooktops) 3 03-26-2013 08:30 AM
Orange Vs Blue Flame cblawler Dryer Repair 1 07-26-2010 08:08 AM
Gas dryer orange glow Alex82 Dryer Repair 0 04-06-2010 02:23 AM
