Discuss
Frigidaire Dryer Intermittent Heat
 in
Dryer Repair
Hi Folks, Got a used washer and dryer (electric) for a steal because the dryer was not heating. When I
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Frigidaire Dryer Intermittent Heat
  #1 (permalink)
Old 09-27-2018, 05:12 AM
Junior Member
hmayes is on a distinguished road
Default Frigidaire Dryer Intermittent Heat
Model Number: AEQ8000FSO   Brand: Frigidaire   Age: 5 - 10 years
Hi Folks,
When I set it up, the dryer actually worked, heat and all. Then that stopped after a couple of loads.
I replaced the thermostat, that did nothing, then replaced the thermal limiter, nothing. After that the dryer heat worked for about a full day, then stopped. Then I replaced the control thermistor. Still nothing.
I finally borrowed a multimeter from work and checked the heating element just for kicks. I get about 10-12 ohms so there is definitely continuity (which makes sense because it works on occasion. I also checked the thermistor and it does read about 52K ohms at room temp and resistance goes down if I heat it by holding the sensor part between my fingers.
If I put the dryer through the function test the heat will sometimes work, sometimes not.
These are the error codes I have gotten:
E5B 170
E8C 031
E9E 001 (I can't figure out what this one is, it's not listed on the tech data sheet, looks like it only tripped once though? and has not come back.)
E4A 023
If I reset the error codes the one that comes back right away is E5B. Actually, I'm not even sure that one ever clears when I try to reset it.
I am thinking I need a new control board, but just wanted to seek some advice before I drop that kind of money.
Thank you!
Related Models
Frigidaire AEQ8700FE0 DRYER
Frigidaire AEQ8700FG0 DRYER
Frigidaire AEQ8700FS0 DRYER
Frigidaire AEQB6000ES0 Frigidaire/dryer
Frigidaire AEQB6000ES1 Frigidaire/dryer
Frigidaire AEQB6000ES2 Frigidaire/dryer
Frigidaire AEQB6400FS0 DRYER
Frigidaire AEQB7000EG0 Frigidaire/dryer
Frigidaire AEQB7000EP0 Frigidaire/dryer
Frigidaire AEQB7000ES0 Frigidaire/dryer
Frigidaire AEQB7000ES1 Frigidaire/dryer
General Electric AER05LHW1 Room air conditioner
General Electric AER05LLG1 ROOM AIR CONDITIONER
General Electric AER05LLS1 ROOM AIR CONDITIONER
General Electric AER05LNH1 ROOM AIR CONDITIONER
General Electric AER05LNL1 ROOM AIR CONDITIONER
General Electric AER05LNQ1 ROOM AIR CONDITIONER
General Electric AER05LPL1 ROOM AIR CONDITIONER
General Electric AER05LPQ1 ROOM AIR CONDITIONER
General Electric AER05LPW1 ROOM AIR CONDITIONER
Admiral AER1110AAH RANGE- F/S STD ELE
Admiral AER1110BAH RANGE- F/S STD ELE
Admiral AER1140AGH RANGE- F/S STD ELE
Admiral AER1150AAH RANGE- F/S STD ELE
Admiral AER1350AAH RANGE- F/S STD ELE
Admiral AER1350AAL RANGE- F/S STD ELE
Admiral AER1350AAT RANGE- F/S STD ELE
Admiral AER1350AMH RANGE- S/C F/S ELE
Admiral AER1350BAH RANGE- S/C F/S ELE
Admiral AER1350BAT RANGE- S/C F/S ELE
Admiral AER1360AGW RANGE- S/C F/S ELE
Admiral AER1360BGW RANGE- S/C F/S ELE
Admiral AER1450AAH RANGE- F/S STD ELE
Admiral AER1450BAH RANGE- F/S STD ELE
Admiral AER2350AMH RANGE- F/S STD ELE
Maytag AER3311WAW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Amana AER4111AAW RANGE- F/S STD ELE
Amana AER4311AAW RANGE- F/S STD ELE
Amana AER5511AAB RANGE- S/C F/S ELE
Amana AER5511AAQ RANGE- S/C F/S ELE
Amana AER5511AAW RANGE- S/C F/S ELE
Amana AER5511ACB RANGE- S/C F/S ELE
Amana AER5511ACW RANGE- S/C F/S ELE
Amana AER5511BAB RANGE- S/C F/S ELE
Amana AER5511BAQ RANGE- S/C F/S ELE
Amana AER5511BAW RANGE- S/C F/S ELE
Amana AER5515QAQ RANGE- S/C F/S ELE
Amana AER5515QAW RANGE- S/C F/S ELE
Amana AER5515QCW RANGE- S/C F/S ELE
Amana AER5515RCW RANGE- S/C F/S ELE
Maytag AER5522VAS0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Maytag AER5522VAW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Maytag AER5522VCS0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Maytag AER5522VCW0 30" ELECTRIC FREESTANDING SELF CLEAN RANGE
Amana AER5710BAH RANGE- S/C F/S ELE
Amana AER5712AAQ RANGE- S/C F/S ELE
Amana AER5712AAS RANGE- S/C F/S ELE
Amana AER5712AAW RANGE- S/C F/S ELE
Amana AER5712AAZ RANGE- S/C F/S ELE
Amana AER5712ACW RANGE- S/C F/S ELE
Amana AER5712ACZ RANGE- S/C F/S ELE
Amana AER5712BAB RANGE- S/C F/S ELE
Amana AER5712BAW RANGE- S/C F/S ELE
Amana AER5712BAZ RANGE- S/C F/S ELE
Amana AER5715QAQ RANGE- S/C F/S ELE
Amana AER5715QAS RANGE- S/C F/S ELE
Amana AER5715QAW RANGE- S/C F/S ELE
Amana AER5715QCB RANGE- S/C F/S ELE
Amana AER5715QCS RANGE- S/C F/S ELE
Amana AER5715QCW RANGE- S/C F/S ELE
Amana AER5715RCB RANGE- S/C F/S ELE
Amana AER5715RCS RANGE- S/C F/S ELE
Amana AER5715RCW RANGE- S/C F/S ELE
Amana AER5722BAB RANGE- S/C F/S ELE
Amana AER5722BAQ RANGE- S/C F/S ELE
Amana AER5722BAS RANGE- S/C F/S ELE
Amana AER5722BAW RANGE- S/C F/S ELE
Amana AER5722CAS RANGE- S/C F/S ELE
Amana AER5725QAF RANGE- S/C F/S ELE
Amana AER5725QAN RANGE- S/C F/S ELE
Amana AER5725QAQ RANGE- S/C F/S ELE
Amana AER5725QAW RANGE- S/C F/S ELE
Amana AER5735QAB RANGE- S/C F/S ELE
Amana AER5735QAF RANGE- S/C F/S ELE
Amana AER5735QAN RANGE- S/C F/S ELE
Amana AER5735QAQ RANGE- S/C F/S ELE
Amana AER5735QAS RANGE- S/C F/S ELE
Amana AER5735QAW RANGE- S/C F/S ELE
Amana AER5815RCB RANGE- S/C F/S ELE
Amana AER5815RCS RANGE- S/C F/S ELE
Amana AER5815RCW RANGE- S/C F/S ELE
Maytag AER5821VAS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5821VAW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAD0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VAW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VCB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VCS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5822VCW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5823XAB0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5823XAS0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5823XAW0 30" ELECTRIC FREESTANDING STANDARD CLEAN RANGE
Maytag AER5830VAB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Maytag AER5830VAD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Maytag AER5830VAS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Maytag AER5830VAW0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVE
Maytag AER5844VAB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Maytag AER5844VAD0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Maytag AER5844VAS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Maytag AER5844VAW0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Maytag AER5844VCB0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Maytag AER5844VCS0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Maytag AER5844VCW0 30" ELECTRIC CERAN FREESTANDING RANGE SELF CLEAN CONVECTION OVEN
Amana AER5845QAB RANGE- F/S STD ELE
Amana AER5845QAF RANGE- F/S STD ELE
Amana AER5845QAN RANGE- F/S STD ELE
Amana AER5845QAS RANGE- F/S STD ELE
Amana AER5845RAB RANGE- S/C F/S ELE
Amana AER5845RAS RANGE- S/C F/S ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrolux Frigidaire Elect Dryer Intermittent Error 63 tecarlson Dryer Repair 1 09-06-2014 06:24 AM
Frigidaire Gas Intermittent Heat rc_cola Dryer Repair 2 02-14-2012 04:55 AM
intermittent dryer heat rpop7723 Dryer Repair 0 02-09-2012 12:25 PM
Intermittent heat Frigidaire Gas Dryer pvanv Dryer Repair 5 10-06-2011 04:10 AM
Gas Dryer Intermittent Heat volvomann Dryer Repair 0 10-11-2010 07:02 PM
