Discuss
Dryer no power
 in
Dryer Repair
I've had a problem with my dryer no light inside and won't start. When i checked the voltage at the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Dryer no power
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-24-2018, 08:43 AM
Junior Member
Tims51688 is on a distinguished road
Default Dryer no power
Brand: Maytag   Age: 1 - 5 years
I've had a problem with my dryer no light inside and won't start. When i checked the voltage at the screws on the dryer one side to neutral was 120 the other side was 110. Then hot to hot was 240. So i assumed it was the dryer i got a new one from rent a center same thing when they brought it. They put their outlet tester on it. It looked like a 240 plug with two lights on it and one light was bright and the other flickered. They told me my outlet was bad so i replaced it. Still nothing so i replaced the breaker. That did not fix it either. I don't have any other ideas. I know the screws aren't loose because i had to reattach the wires on outlet and breaker. Could it be the wiring between the two? That didn't seem likely to me because it's getting voltage just not quite enough on the one side. Thanks for any help.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dryer has power washer has no power on Kenmore Stackable surveyor1951 Washer Repair 20 01-17-2015 11:47 AM
Dryer will not power ON lriddiford Dryer Repair 1 12-06-2010 03:47 PM
No Power on dryer, power to outlet and cord dorn27 Dryer Repair 1 07-26-2010 05:15 PM
Maytag Neptune Dryer - no power at all after power cord poli Dryer Repair 0 07-09-2010 07:46 AM
Admiral Dryer no power to light or dryer Do-right Dryer Repair 1 01-14-2008 01:15 PM
