Discuss
gas dryer has faint gas smell in drum
 in
Dryer Repair
My whirlpool lgb6200pqo has a weak natural gas smell in the drum when not in use. I've checked all the
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » gas dryer has faint gas smell in drum
  #1 (permalink)
Old 08-30-2018, 11:40 PM
Junior Member
jimtone is on a distinguished road
Default gas dryer has faint gas smell in drum
Model Number: lgb6200pqo   Brand: Whirlpool   Age: Less than 1 year
My whirlpool lgb6200pqo has a weak natural gas smell in the drum when not in use. I've checked all the gas lines and shut off for leaks but none found, then I took off the top and front along with electric plug removal and took out the drum and belt to expose burner assy. I checked the gas line with soap at the valve for leaks and all other gas plugs on the valve but they had no leaks. I then wiped some soap/water over the orifice and it made a small slow filling bubble. I replaced my 2 solenoids last week with used ones from another same type dryer because the burner was intermitent and would lite gas several times but not several other times. I also ordered the new solenoids and will install when they arrive, but do you think the new solenoids will shut the gas flow completely when not in use or do you think it is my gas valve that's defective? I've read in several places where the gas valve is most likely not to fail but that doesn't mean they never fail. Before ordering a new gas valve, I'll remove the valve from my parts dryer to install and test after I install the new solenoids on my leaking valve to see if those solenoids make it behave. Let me know if anything can be done to adjust or repair my leaking gas valve?
Related Models
Whirlpool LGB6300LW0 RESIDENTIAL DRYER
Whirlpool LGB6300LW1 29"GAS DRYER
Whirlpool LGB6300PW0 29"GAS DRYER
Whirlpool LGB6300PW1 29"GAS DRYER
Whirlpool LGB64000LW0
Whirlpool LGB6400KQ0 DRYER
Whirlpool LGB6400KQ1 DRYER
Whirlpool LGB6400LW0 RESIDENTIAL DRYER
Whirlpool LGB6400LW1 29"GAS DRYER
Frigidaire LGBD2431LB0A DISHWASHER
Frigidaire LGBD2431LF0A DISHWASHER
Frigidaire LGBD2431LQ0A DISHWASHER
Frigidaire LGBD2431LW0A DISHWASHER
Frigidaire LGBD2432LB0A DISHWASHER
Frigidaire LGBD2432LF0A DISHWASHER
Frigidaire LGBD2432LQ0A DISHWASHER
Frigidaire LGBD2432LW0A DISHWASHER
Admiral LGC1330ADB SURFACE UNIT- GAS
Admiral LGC1330ADC SURFACE UNIT- GAS
Admiral LGC1330ADW SURFACE UNIT- GAS
Amana LGC20AW DRYER- GAS
Whirlpool LGC5000PQ0 29" GAS DRYER
Whirlpool LGC5000PQ1 29" GAS DRYER
Amana LGC50AW DRYER- GAS
Whirlpool LGC6646AN0 GAS DRYER
Whirlpool LGC6646AN1 GAS DRYER
Whirlpool LGC6646AN2 GAS DRYER
Whirlpool LGC6646AQ0 Residential Dryer
Whirlpool LGC6646AQ1 GAS DRYER
Whirlpool LGC6646AQ2 GAS DRYER
Whirlpool LGC6646AW0 Residential Dryer
Whirlpool LGC6646AW1 GAS DRYER
Whirlpool LGC6646AW2 GAS DRYER
Whirlpool LGC6646AZ0 Dryer
Whirlpool LGC6646AZ1 GAS DRYER
Whirlpool LGC6646AZ2 GAS DRYER
Whirlpool LGC6848AN0 GAS DRYER
Whirlpool LGC6848AN1 GAS DRYER
Whirlpool LGC6848AN2 GAS DRYER
Whirlpool LGC6848AN3 GAS DRYER
Whirlpool LGC6848AQ0 Residential Dryer
Whirlpool LGC6848AQ1 GAS DRYER
Whirlpool LGC6848AQ2 GAS DRYER
Whirlpool LGC6848AQ3 GAS DRYER
Whirlpool LGC6848AW0 GAS DRYER
Whirlpool LGC6848AW1 TECH SHEET - DRYER - REVISION REL.
Whirlpool LGC6848AW2 GAS DRYER
Whirlpool LGC6848AW3 GAS DRYER
Whirlpool LGC6848AZ1 GAS DRYER
Whirlpool LGC6848AZ2 GAS DRYER
Whirlpool LGC6848AZ3 GAS DRYER
Whirlpool LGC7646DQ0 GAS DRYER
Whirlpool LGC7646DQ1 GAS DRYER
Whirlpool LGC7646DZ0 GAS DRYER
Whirlpool LGC7646DZ1 GAS DRYER
Whirlpool LGC7848DQ0 GAS DRYER
Whirlpool LGC7848DQ1 GAS DRYER
Whirlpool LGC7848DZ0 GAS DRYER
Whirlpool LGC7848DZ1 GAS DRYER
Whirlpool LGC7858AN0 GAS DRYER
Whirlpool LGC7858AN1 GAS DRYER
Whirlpool LGC7858AN2 GAS DRYER
Whirlpool LGC7858AQ0 GAS DRYER
Whirlpool LGC7858AQ1 GAS DRYER
Whirlpool LGC7858AQ2 GAS DRYER
Whirlpool LGC7858AW0 Residential Dryer
Whirlpool LGC7858AW1 GAS DRYER
Whirlpool LGC7858AW2 GAS DRYER
Whirlpool LGC7858AZ0 GAS DRYER
Whirlpool LGC7858AZ1 GAS DRYER
Whirlpool LGC7858AZ2 GAS DRYER
Whirlpool LGC8858DQ0 GAS DRYER
Whirlpool LGC8858DQ1 GAS DRYER
Whirlpool LGC8858DZ0 GAS DRYER
Whirlpool LGC8858DZ1 GAS DRYER
Whirlpool LGC8858EQ0 GAS DRYER
Whirlpool LGC8858EQ1 DRYERS
Whirlpool LGC8858EQ2 GAS DRYER
Whirlpool LGC8858EQ3 GAS DRYER
Whirlpool LGC8858EZ0 GAS DRYER
Whirlpool LGC8858EZ1 DRYERS
Whirlpool LGC8858EZ2 GAS DRYER
Whirlpool LGC8858EZ3 GAS DRYER
Whirlpool LGC9000PW0 29" GAS DRYER
Whirlpool LGC9000PW1 29" GAS DRYER
Amana LGD20AW DRYER- GAS
Amana LGD251 WASHER-TOP LOADING
Amana LGD251 DRYER- GAS
Amana LGD312 DRYER- GAS
Amana LGD32AW DRYER- GAS
Amana LGD451 WASHER-TOP LOADING
Amana LGD451 DRYER- GAS
Amana LGD512 DRYER- GAS
Amana LGD57AW DRYER- GAS
Amana LGD65AW DRYER- GAS
Amana LGD851 WASHER-TOP LOADING
Amana LGD851 DRYER- GAS
Amana LGD912 DRYER- GAS
Amana LGD951 WASHER-TOP LOADING
Amana LGD951 DRYER- GAS
Whirlpool LGE9848BQ1 GAS DRYER
Whirlpool LGE9848BQ2 GAS DRYER
Whirlpool LGE9848BZ1 GAS DRYER
Whirlpool LGE9848BZ2 GAS DRYER
Frigidaire LGEF3031KBA ELECTRIC RANGE
Frigidaire LGEF3031KBB ELECTRIC RANGE
Frigidaire LGEF3031KBC ELECTRIC RANGE
Frigidaire LGEF3031KMA ELECTRIC RANGE
Frigidaire LGEF3031KMB ELECTRIC RANGE
Frigidaire LGEF3031KWA ELECTRIC RANGE
Frigidaire LGEF3031KWB ELECTRIC RANGE
Frigidaire LGEF3031KWC ELECTRIC RANGE
Frigidaire LGEF3033KBA ELECTRIC RANGE
Frigidaire LGEF3033KBB ELECTRIC RANGE
Frigidaire LGEF3033KBC ELECTRIC RANGE
Frigidaire LGEF3033KBD ELECTRIC RANGE
Frigidaire LGEF3033KBE ELECTRIC RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Dryer - faint control panel lights mordonez52 Dryer Repair 9 05-02-2017 10:03 PM
LG WM2016CW - Rubber smell, smoke & wobbly drum - replace spider? nick2196 Washer Repair 1 05-01-2016 07:49 AM
Drum stops, buring smell Dick E Dryer Repair 2 03-17-2014 03:07 AM
GE washer top load - burnt smell at the end of spin seems from inside the drum geotech123 Washer Repair 1 11-26-2013 05:36 PM
led diplay faint ahorace Oven Repair (including Ranges and Cooktops) 0 12-30-2009 12:33 PM
