Discuss
Maytag Dryer No Heat "Fixed Itself"?
 in
Dryer Repair
Model: MDET446AYW My dryer started tumbling with no heat. The drum turned and the fan ran, but no heat was
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Dryer No Heat "Fixed Itself"?
  #1 (permalink)
Old 08-10-2018, 07:47 PM
Junior Member
Astonephus is on a distinguished road
Question Maytag Dryer No Heat "Fixed Itself"?
Brand: Maytag   Age: 5 - 10 years
Model: MDET446AYW
My dryer started tumbling with no heat. The drum turned and the fan ran, but no heat was coming out (In hindsight, no glow in the back either). I disassembled the dryer and did an ohm test on the the standard electrical bits (thermal fuse, thermostat, etc.) and all checked out. I removed the heating element to check for breakage and it looked fine. An ohm test from one side of the heating element to the other also checked out. I put everything back together, cleaned out the inside of the dryer of some excess lint, figured I'd try it one more time (we could use it to air fluff dry clothes until I fixed it). And.....VIOLA! It was heating up just fine (now there was glow).
I don't like "fix itself" problems. Nothing moves inside of the dryer that would create a loose connection or anything like that, so I can't imagine what triggered the initial problem nor why it randomly started working after being disassembled and reassembled. Does anyone have any ideas on this magic?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Bravos Dryer "no heat" brobriffin Dryer Repair 4 04-12-2018 01:41 PM
Fridge keeps leaking water from freezer even though I "fixed" it Dg2015 Refrigerator & Freezer Repair 0 07-05-2015 08:49 PM
