Discuss
How to wire a 4 prong power cord to an older dryer
 in
Dryer Repair
My current dryer stops working and I need to use an old dryer as a temporary replacement. Please help me
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » How to wire a 4 prong power cord to an older dryer
  #1 (permalink)
Old 07-15-2018, 04:00 PM
Junior Member
hochoi is on a distinguished road
Default How to wire a 4 prong power cord to an older dryer
Brand: Maytag   Age: More than 10 years
My current dryer stops working and I need to use an old dryer as a temporary replacement. Please help me to wire the 4 prong power cord to an older dryer which has only 3 prong. Picture is attached. Thanks in advance.
  #2 (permalink)
Old 07-16-2018, 07:25 AM
ohm ohm is offline
Senior Member
ohm is on a distinguished road
Default
White wire must go to neutral not with ground.
File Type: jpg Screen Shot 2018-02-26 at 10.31.55 AM.jpg (72.8 KB, 4 views)
  #3 (permalink)
Old 07-16-2018, 07:27 AM
ohm ohm is offline
Senior Member
Default
This old post.Converting from a 3-prong cord to a 4-prong dryer cord
Model number would be good if you have it.
  #4 (permalink)
Old 07-16-2018, 07:38 AM
ohm ohm is offline
Senior Member
Default
Ok now I see you going from a 4 prong to a three.Best to know a model number for sure.I leave that other information there for future guest!
  #5 (permalink)
Old 07-16-2018, 10:20 AM
Junior Member
Default
ohm, I am going from 3 to 4 prong cord.
There are 2 white wires from inside the dryer, both connected to the neutral lug. Which one is the ground one?
The model number is MDE6657BYW.
  #6 (permalink)
Old 07-16-2018, 01:12 PM
ohm ohm is offline
Senior Member
Default
Under the neutral terminal there is What looks like a 5/16 screw that has a grounding strap on it and part of it is under the center neutral nut or nuts Remove That.Wire your 4 prong power cord up just like in the picture I posted EXCEPT that white wire.Only a green wire from the 4 wire dryer cord goes there. So Black is to the Left( L1 ) White from the 4 wire power cord to the CENTER and RED from the power cord on the right side of Neutral L2 and your done. Wiring diagram in parts breakdown below.
  #7 (permalink)
Old 07-16-2018, 01:18 PM
ohm ohm is offline
Senior Member
Default
Part number: Y312184
This is the part you are removing from the center terminal block.
  #8 (permalink)
Old 07-16-2018, 01:27 PM
ohm ohm is offline
Senior Member
Default
Part number: WP33001244
Here is a video of the whole terminal block and a 4 wire hook up.Notice the part I posted is there put on the same neutral terminal so it could used to convert back to a 3 wire power cord or just remove it and keep it a safe place.
  #9 (permalink)
Old 07-16-2018, 05:53 PM
Junior Member
Default
Thank a lot, ohm. This video seems to show exactly the dryer I have. One curious question: the two white wires from inside the dryer, both are connected to the neutral jug. Are they both neutral or one is ground and one is neutral. If one is ground and one is neutral, then should the ground one connected to the green wire from the power cord?
  #10 (permalink)
Old 07-16-2018, 05:59 PM
ohm ohm is offline
Senior Member
Default
Both whites are neutral.Green wire from your 4 prong power cord is screwed to the frame of the dryer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Converting from a 3-prong cord to a 4-prong dryer cord VLHastings Dryer Repair 2 07-16-2018 06:03 PM
4 prong power cord - 3 prong wall outlet??? BradleyT Dryer Repair 0 08-09-2011 04:45 PM
Washer machine power cord 3 prong missing ground prong REplace? Is it ok? maddy Washer Repair 1 06-17-2011 04:36 PM
Changeing a 3 prong to a 4 prong power cord Manteus26 Dryer Repair 1 12-23-2010 03:55 AM
