Discuss
Motor just hums quietly. Electric odor. Drum doesn't rotate
 in
Dryer Repair
I just replaced the drum rollers, drum belt, and tension pulley. Motor was fine before, but machine squeaked loudly and
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Motor just hums quietly. Electric odor. Drum doesn't rotate
  #1 (permalink)
Old 07-04-2018, 10:51 AM
Junior Member
woodtf is on a distinguished road
Question Motor just hums quietly. Electric odor. Drum doesn't rotate
Model Number: SDE3606AYW   Brand: Maytag   Age: 5 - 10 years
I just replaced the drum rollers, drum belt, and tension pulley. Motor was fine before, but machine squeaked loudly and made grinding noise. Gave it a try after reassembly and now motor doesn't work. Seems like it's straining, and then cuts off. I tried just briefly before unplugging machine.
Related Models
Maytag SDE3606AYW DRYER- ELE
Maytag SDE3606AZW DRYER- ELE
Maytag SDE4000AYW DRYER- ELE
Maytag SDE4000AZW DRYER- ELE
Maytag SDE405DAYW DRYER- ELE
Maytag SDE4606AYW DRYER- ELE
Maytag SDE4606AZW DRYER- ELE
Maytag SDE505DAYQ DRYER- ELE
Maytag SDE505DAYW DRYER- ELE
Maytag SDE505DAZW DRYER- ELE
Maytag SDE515DAYW DRYER- ELE
Maytag SDE515DAZW DRYER- ELE
Maytag SDE5401AYW DRYER- ELE
Maytag SDE5401AZW DRYER- ELE
Maytag SDE5701AYQ DRYER- ELE
Maytag SDE5701AYW DRYER- ELE
Maytag SDE5701AZW DRYER- ELE
Maytag SDG2606AWW DRYER- GAS
Maytag SDG305DAWW DRYER- GAS
Maytag SDG3606AWQ DRYER- GAS
Maytag SDG3606AWW DRYER- GAS
Maytag SDG4000AWW DRYER- GAS
Maytag SDG405DAWW DRYER- GAS
Maytag SDG4606AWW DRYER- GAS
Maytag SDG505DAWQ DRYER- GAS
Maytag SDG505DAWW DRYER- GAS
Maytag SDG505DAXW DRYER- GAS
Maytag SDG515DAWW DRYER- GAS
Maytag SDG5401AWW DRYER- GAS
Maytag SDG5401AXW DRYER- GAS
Maytag SDG5701AWQ DRYER- GAS
Maytag SDG5701AWW DRYER- GAS
Maytag SDG5701AXW DRYER- GAS
Whirlpool SDH481B0 DEHUMIDIFIER
Whirlpool SDH501B20 DEHUMIDIFIER
Amana SDI22A REF - SXS/I&W
Amana SDI22A-A REF - SXS/I&W
Amana SDI22A-AG REF - SXS/I&W
Amana SDI22A-C REF - SXS/I&W
Amana SDI22B REF - SXS/I&W
Amana SDI22B-A REF - SXS/I&W
Amana SDI22B-C REF - SXS/I&W
Amana SDI22B-G REF - SXS/I&W
Amana SDI22B-L REF - SXS/I&W
Amana SDI22C REF - SXS/I&W
Amana SDI22C-A REF - SXS/I&W
Amana SDI22C-C REF - SXS/I&W
Amana SDI22C-G REF - SXS/I&W
Amana SDI22C-L REF - SXS/I&W
Amana SDI22D REF - SXS/I&W
Amana SDI22E REF - SXS/I&W
Amana SDI22E-1-A REF - SXS/I&W
Amana SDI22E-1-C REF - SXS/I&W
Amana SDI22E-A REF - SXS/I&W
Amana SDI22E-C REF - SXS/I&W
Amana SDI22E-G REF - SXS/I&W
Amana SDI22E-L REF - SXS/I&W
Amana SDI22E1 REF - SXS/I&W
Amana SDI22E1G REF - SXS/I&W
Amana SDI22E1L REF - SXS/I&W
Amana SDI22F Ref - SXS/I&W
Amana SDI22F-1 REF - SXS/I&W
Amana SDI22F-1-G REF - SXS/I&W
Amana SDI22F-1-L REF - SXS/I&W
Amana SDI22F-G Ref - SXS/I&W
Amana SDI22F-L Ref - SXS/I&W
Amana SDI22FA REF - SXS/I&W
Amana SDI22FC REF - SXS/I&W
Amana SDI22FG Ref - SXS/I&W
Amana SDI22FL Ref - SXS/I&W
Amana SDI22G Ref - SXS/I&W
Amana SDI22GG Ref - SXS/I&W
Amana SDI22GL REF - SXS/I&W
Amana SDI22N REF - SXS/I&W
Amana SDI22N-1 REF - SXS/I&W
Amana SDI22N-1-A REF - SXS/I&W
Amana SDI22N-1-AG REF - SXS/I&W
Amana SDI22N-1-C REF - SXS/I&W
Amana SDI22N-A REF - SXS/I&W
Amana SDI22N-AG REF - SXS/I&W
Amana SDI22N-C REF - SXS/I&W
Amana SDI22W REF - SXS/I&W
Amana SDI22W-A REF - SXS/I&W
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Malber Washer/dryer - drum doesn't rotate koala Washer Repair 1 06-19-2014 07:06 AM
Maytag washer motor does not run/Drum does not rotate elaraujo Washer Repair 1 03-21-2013 03:42 PM
Dryer drum does not rotate crocha Dryer Repair 5 11-16-2012 07:58 PM
Motor Does Not Rotate Drum slappetito Washer Repair 5 05-19-2009 01:56 PM
motor hums but drum will not turn judy71635@alltel.net Dryer Repair 1 07-30-2008 08:28 PM
