Discuss
Whirlpool Dryer Has high heat but not Low heat
 in
Dryer Repair
I have a Propane dryer that the timer does not move when set. It also does not work on automatic
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool Dryer Has high heat but not Low heat
  #1 (permalink)
Old 06-26-2018, 07:44 AM
Junior Member
pjineson is on a distinguished road
Default Whirlpool Dryer Has high heat but not Low heat
Model Number: LGR5636EQ3   Brand: Whirlpool   Age: More than 10 years
I have a Propane dryer that the timer does not move when set. It also does not work on automatic dry but will work on time dry high heat. When set to low heat it does not dry. Thoughts? Is it just the timer or something else?
Related Models
Whirlpool LGR5636EQ3 DRYER
Whirlpool LGR5636EZ0 DRYER
Whirlpool LGR5636EZ1 DRYER
Whirlpool LGR5636EZ2 DRYER
Whirlpool LGR5636EZ3 DRYER
Whirlpool LGR5636JQ0 DRYER
Whirlpool LGR5636JQ1 DRYER
Whirlpool LGR5636JT0 DRYER
Whirlpool LGR5636JT1 DRYER
Whirlpool LGR5636KQ0 DRYER
Whirlpool LGR5636KQ1 DRYER
Whirlpool LGR5636KT0 DRYER
Whirlpool LGR5636KT1 DRYER
Whirlpool LGR5636LG0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ0 RESIDENTIAL DRYER
Whirlpool LGR5636LQ1 29"GAS DRYER
Whirlpool LGR5636LT0 RESIDENTIAL DRYER
Whirlpool LGR5636LT1 29"GAS DRYER
Whirlpool LGR5636LW0 RESIDENTIAL DRYER
Whirlpool LGR5636PQ0 29"GAS DRYER
Whirlpool LGR5636PQ1 29"GAS DRYER
Whirlpool LGR5636PT0 29"GAS DRYER
Whirlpool LGR5636PT1 29"GAS DRYER
Whirlpool LGR5638AN1 GAS DRYER
Whirlpool LGR5638AN2 GAS DRYER
Whirlpool LGR5638AN3 GAS DRYER
Whirlpool LGR5638AW0 Residential Dryer
Whirlpool LGR5638AW1 GAS DRYER
Whirlpool LGR5638AW2 GAS DRYER
Whirlpool LGR5638AW3 GAS DRYER
Whirlpool LGR5644AN1
Whirlpool LGR5644AN2 GAS DRYER
Whirlpool LGR5644AW0 Residential Dryer
Whirlpool LGR5644AW1
Whirlpool LGR5644AW2 GAS DRYER
Whirlpool LGR5644EQ0 GAS DRYER
Whirlpool LGR5644EQ1 DRYERS
Whirlpool LGR5644EQ2 GAS DRYER
Whirlpool LGR5644EQ3 GAS DRYER
Whirlpool LGR5644EZ0 GAS DRYER
Whirlpool LGR5644EZ1 DRYERS
Whirlpool LGR5644EZ2 GAS DRYER
Whirlpool LGR5644EZ3 GAS DRYER
Whirlpool LGR5644JQ0 GAS DRYER
Whirlpool LGR5644JQ1 RESIDENTIAL DRYER
Whirlpool LGR5644JQ2 GAS DRYER
Whirlpool LGR5644JQ3 29" GAS DRYER
Whirlpool LGR5644JT0 GAS DRYER
Whirlpool LGR5644JT1 RESIDENTIAL DRYER
Whirlpool LGR5644JT2 GAS DRYER
Whirlpool LGR5644JT3 29" GAS DRYER
Whirlpool LGR5644PQ0 29" GAS DRYER
Whirlpool LGR5644PQ1 29" GAS DRYER
Whirlpool LGR5700KQ0 DRYER
Whirlpool LGR5700KQ1 DRYER
Whirlpool LGR5700KT0 DRYER
Whirlpool LGR5700KT1 DRYER
Whirlpool LGR5848EQ0 GAS DRYER
Whirlpool LGR5848EQ1 GAS DRYER
Whirlpool LGR5848EQ2 GAS DRYER
Whirlpool LGR5848EQ3 DRYERS
Whirlpool LGR5848EQ4 DRYERS
Whirlpool LGR5848EQ5 GAS DRYER
Whirlpool LGR5848EQ6 GAS DRYER
Whirlpool LGR6611LQ0 RESIDENTIAL DRYER
Whirlpool LGR6611LQ1 29"GAS DRYER
Whirlpool LGR6611PQ0 29" GAS DRYER
Whirlpool LGR6620PQ0 29"GAS DRYER
Whirlpool LGR6620PQ1 29"GAS DRYER
Whirlpool LGR6620PT0 29"GAS DRYER
Whirlpool LGR6620PT1 29"GAS DRYER
Whirlpool LGR6621PQ0 29" GAS DRYER
Whirlpool LGR6634BN0 GAS DRYER
Whirlpool LGR6634BN1 GAS DRYER
Whirlpool LGR6634BN2 GAS DRYER
Whirlpool LGR6634BQ0 GAS DRYER
Whirlpool LGR6634BQ1 GAS DRYER
Whirlpool LGR6634BQ2 GAS DRYER
Whirlpool LGR6634BW0 GAS DRYER
Whirlpool LGR6634BW1 GAS DRYER
Whirlpool LGR6634BW2 GAS DRYER
Whirlpool LGR6634DQ0 GAS DRYER
Whirlpool LGR6634DQ1 GAS DRYER
Whirlpool LGR6634DW0 GAS DRYER
Whirlpool LGR6634DW1 GAS DRYER
Whirlpool LGR6634DZ0 GAS DRYER
Whirlpool LGR6634DZ1 GAS DRYER
Whirlpool LGR6636PW0 29" GAS DRYER
Whirlpool LGR6636PW1 29" GAS DRYER
Whirlpool LGR6638DQ0 GAS DRYER
Whirlpool LGR6638DQ1 GAS DRYER
Whirlpool LGR6638DW0 GAS DRYER
Whirlpool LGR6638DW1 GAS DRYER
Whirlpool LGR6638DZ0 GAS DRYER
Whirlpool LGR6638DZ1 GAS DRYER
Whirlpool LGR6644DQ0 GAS DRYER
Whirlpool LGR6644DQ1 GAS DRYER
Whirlpool LGR6644DZ0 GAS DRYER
Whirlpool LGR6644DZ1 GAS DRYER
Whirlpool LGR6646BN0 GAS DRYER
Whirlpool LGR6646BN1 GAS DRYER
Whirlpool LGR6646BN2 GAS DRYER
Whirlpool LGR6646BW0 GAS DRYER
Whirlpool LGR6646BW1 GAS DRYER
Whirlpool LGR6646BW2 GAS DRYER
Whirlpool LGR6646DN1 GAS DRYER
Whirlpool LGR6646DW1 GAS DRYER
Whirlpool LGR6646PW0 29" GAS DRYER
Whirlpool LGR6646PW1 29" GAS DRYER
Whirlpool LGR6848AN1 GAS DRYER
Whirlpool LGR6848AN2 GAS DRYER
Whirlpool LGR6848AQ2 GAS DRYER
Whirlpool LGR6848AW0 Residential Dryer
Whirlpool LGR6848AW1 GAS DRYER
Whirlpool LGR6848AW2 GAS DRYER
Whirlpool LGR6848AZ2 GAS DRYER
Whirlpool LGR7620KQ0 RESIDENTIAL DRYER
Whirlpool LGR7620KQ1 RESIDENTIAL DRYER
Whirlpool LGR7620KT0 RESIDENTIAL DRYER
Whirlpool LGR7620KT1 RESIDENTIAL DRYER
  #2 (permalink)
Old 06-27-2018, 04:28 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
It could be the timer or it could be this part.
Whirlpool WP3387134 Dryer Cycling Thermostat - AppliancePartsPros.com
It kind of sounds like the timer, but testing the other part is easy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana dryer wont heat on low heat but does on high heat Rrcanada Dryer Repair 0 06-02-2018 08:36 AM
Whirlpool dryer turns off when using high heat SheepNutz Dryer Repair 1 06-27-2017 08:43 PM
Whirlpool dryer only works on High Heat ScottyJ Dryer Repair 9 11-14-2014 05:12 PM
Whirlpool dryer stays on high heat kjv42 Dryer Repair 3 11-06-2013 09:27 AM
Whirlpool gas dryer high heat only. dbaro Dryer Repair 3 11-05-2010 07:52 PM
